Nick Guest
Solid state relay comes on with +5v, but doesnt turn off? |
Posted: Thu Sep 02, 2004 9:00 am |
I have an omron solid state relay for 120vac, I'm testing with DC LEDs to see if it works. It does turn on, but will not turn off unless I pull the power.
Nick |
newguy
Posted: Thu Sep 02, 2004 9:26 am |
A SSR is usually constructed out of a triac or something like that. A triac will start to conduct when current is fed into the trigger, and won't stop until the *controlled* (switched) voltage falls to zero.
What you're seeing is normal. Try it with a light bulb - you'll see that it turns off when the mains ac voltage falls to zero (after removal of the trigger). |
John Morley
Posted: Thu Sep 02, 2004 9:31 am |
Nick,
A quick google search indicates that there are "AC output", "DC Output" and "Universal (AC/DC) Output" solid state relays. Yours seems to be the AC only variety. Some SSR's apparently require the zero-crossing of the AC signal to switch properly. _________________ John Morley |
Nick Guest
Posted: Thu Sep 02, 2004 9:34 am |
Thanks for the info!
Nick |
