LESS than <0
scanan
LESS than <0
PostPosted: Wed Sep 01, 2004 5:05 am     Reply with quote
why
if(x<0) don't work
alexbilo
PostPosted: Wed Sep 01, 2004 5:47 am     Reply with quote
why
if(x<0) don't work
Actually, it does... I think that posting a little more details about your code would help...
What make you think that it doesn't work?
Alex
Re: LESS than <0
PostPosted: Wed Sep 01, 2004 6:38 am     Reply with quote
scanan wrote:
why
if(x<0) don't work
It won't work, if 'x' is an _unsigned_ integer. Remember the default 'int' type is unsigned...
rnielsen
PostPosted: Wed Sep 01, 2004 8:25 am     Reply with quote
Try:
signed int8 x;
that should make 'x' be valid from -128 to 128. If you omit the 'signed' portion it makes 'x' valid from 0 to 255. That one bit me when I first started using CCS.
Ronald
bdavis
PostPosted: Wed Sep 01, 2004 10:31 pm     Reply with quote
How about -127 to 128 instead of -128 to 128? I'm sure that's what you probably meant anyway Very Happy
PostPosted: Thu Sep 02, 2004 2:25 am     Reply with quote
And how about -128 to 127? 0b01111111 is 127.I'm sure that's what you probably meant anyway Smile
rnielsen
PostPosted: Thu Sep 02, 2004 8:33 am     Reply with quote
Ok, Ok. Got some smart ones out there.
I guess I'll just walk over to the bit bucket and toss one in the garbage to make it and even -127. Shocked
