help about 16f676
mirberti
help about 16f676
PostPosted: Tue Aug 31, 2004 11:17 am     Reply with quote
hi,
I make a project with 16f676.
#include <16F676.h>
#device adc=10
#fuses INTRC_IO,NOWDT
#define In0    PIN_C1
#define In1    PIN_C2
#define In2    PIN_C0
#define In3    PIN_C3
#define In4    PIN_C4
#define In5    PIN_C5
#define Out0   PIN_A4
#define Out1   PIN_A2
#define Out2   PIN_A5
#define Out3   PIN_A1
#define An0    PIN_A0
unsigned long lettan=0;
   setup_adc_ports(sAN0|VSS_VDD);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_4);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   set_adc_channel(0);
   delay_ms(10);
   while(1) {
      lettan = READ_adc();
      output_bit(Out3,1);
      output_bit(Out2,1);
If I set Out3(Pin RA1) only the output pin is HIGHT, but if I set Out2 and Out3 or another output the Out3(Pin RA1) blink.
Why ????
could alyone help me ???
Regards Mirrko
PostPosted: Tue Aug 31, 2004 12:51 pm     Reply with quote
1. Post your version of the compiler.
2. What do you have connected to each of your "Out" pins ?
Describe the circuit (list all components).
3. What is the purpose of your test program ? It doesn't appear
to do anything useful. The while() loop doesn't have a delay_ms()
statement, so it runs at full speed. The "Out" pins are always set
to 1, so they will never change. The read_adc() value is not
displayed. So what's the purpose ?
mirberti
help about 16f676
PostPosted: Fri Sep 03, 2004 9:13 am     Reply with quote
My compiler version is : 3.148
The output pin is connected with ULN2003 and after an relay.
When I set the output the pin blink in high freqency and I dont understand why.
I supposed is the setup of PIC but I don't understad who is it.
I used PIC16F676 with internal 4 MHZ oscillator.
regards
Mirko
languer
PostPosted: Tue Sep 07, 2004 2:05 pm     Reply with quote
I think verifying the connections to your pins is in order (if you have not found your problem yet).
It sounds like your device may be reseting. How do you have MCLR connected (can you use the NOMCLR option)?
Are you trying to source too much current (that would reset your device as well)?
Trampas
PostPosted: Tue Sep 07, 2004 2:39 pm     Reply with quote
mirberti,
In MPLAB select View->Dissassembly. This will display the C code and the assembly instructions the C code produced. Then cut an paste that code here. Looking at the disassembly it will be easy to see if the code is correct. Then if the code is correct you know your problem is most likely a hardware problem like the watch dog enabled, or the brown out detection.
Trampas
maria
help with 16F676
PostPosted: Fri Dec 03, 2004 10:08 am     Reply with quote
Hi
I have had exactly the same problem with the PIC12F675(CCS PCM v 3.099).
I sorted out as soon as I got rid of the built-in function for disabling the comparator, i.e
and replaced by
#byte CMCON=0X19
and inside 'main'
CMCON=0x07; //Disable the comparator
and the output stopped blinking.
I checked the memory map for the PIC16F676 and this register is at the same position.
I hope this helps Razz
