ljb
setup_uart |
Posted: Tue Aug 31, 2004 5:28 am |
I have the latest version and nothing is listed under help, but the readme file has :
SETUP_UART now accepts the following new options for chips with the EUART H/W:
UART_AUTODETECT
UART_AUTODETECT_NOWAIT
UART_WAKEUP_ON_RDA
If these are new, does this mean there are other options which can be set.
I have been having problems with the h/w uart failing after operating ok for days or weeks. The prog still runs but comms stops. I am using the f876, i2c and timer0 with prescaler.
Any ideas appreciated.
Cheers
Les |
dyeatman
We need something to go on!! |
Posted: Tue Aug 31, 2004 6:35 am |
The F876 does not have a EUART, it has a USART so those options don't apply for you.
We are not mindreaders and without posting your code and some kind of details it is a total crapshoot to guess why you are having problems.
Post the first 15 lines or so of your code first so we can see how you are setting things up. Be sure to include your #use RS232 and #use I2C lines.
Next, please give us some details about the problem you are having.
What comms stop? All of them, the RS2342, the I2C? Does the chip get into a loop at some point in the program? What is still working? We need some info here!! |
Re: setup_uart |
Posted: Tue Aug 31, 2004 7:00 am |
ljb wrote: | I have the latest version and nothing is listed under help, but the readme file has :
UART_AUTODETECT
UART_WAKEUP_ON_RDA
Cheers
Les |
Obvious question, is whether you have 'errors' enabled. If not (and you are not clearing these yourself), it only takes one overrun error, for the UART to be completely hung...
If your system is 'mission critical', and comms are regular (a packet every few seconds perhaps), then consider using the watchdog, with an interrupt driven counter, which is set to a value, whenever data is received. In the interrupt, if the counter is non-zero, reset the watchdog, and decrement the counter. This way you can have a watchdog that will trigger after several seconds, if the comms are not being seen, and reset the chip.
ljb
Posted: Tue Aug 31, 2004 7:10 am |
The reason I asked about the setup_uart is that it is specified in the f876 file within the device library, as shown below :
Why, if it is not implemented?
// Constants used in setup_uart() are:
// FALSE - Turn UART off
// TRUE - Turn UART on
#define UART_ADDRESS 2
#define UART_DATA 4
Is there somethink I am missing here?
Thanks for help
Les
Ps. I think my comms prob may actually be the i2c (ram device) hanging or looping when the last address is reached.
I |
Posted: Tue Aug 31, 2004 7:25 am |
ljb wrote: | The reason I asked about the setup_uart is that it is specified in the f876 file within the device library, as shown below :
#define UART_DATA 4
Thanks for help
Les
I |
The 'point' is that the same command (setup_uart), is used on lots of different chips. On your chip, the only functions supported, are 'true', and 'false' to enable/disable the UART. On latter chips, new keywords are added (and listed in the .h file). You could in fact code your own 'errors' clearing routine, by testing the UART for any errors, and if one is found, issuing first a setup_uart(false)', then a 'setup_uart(true)', which restarts the UART, and clears the error. Adding the ERRORS flag to the RS232 declaration, does this automatically.
ljb
Posted: Tue Aug 31, 2004 7:31 am |
Understand now, many thanks for your help.
Les |
