GPS receive on pin B2, how to timeout (PIC16F876)
runtime
PostPosted: Sat Aug 28, 2004 3:58 pm     Reply with quote
Hello all,
PIC16f876
I am receiving GPS readings on pin B2, I did not used any software or hardware interrupts to read the GPS because I wanted to poll the GPS instead of jumping to an interrupt routine every time a GPS char is present.
So, everytime I need a GPS position, I call a routine to get the characters using fgetc(GPS), this works ok if the GPS is connected but hangs up when GPS is disconnected, how can I timeout when GPS is disconnected?
Thank you in advance
Peter
PostPosted: Sat Aug 28, 2004 5:56 pm     Reply with quote
Have you tried polling using kbhit() before calling fgetc()?
Humberto
PostPosted: Sun Aug 29, 2004 7:11 am     Reply with quote
Does the level of B2 change whenever you disconnect the GPS ?
If so, put a pull up resistor (10K) in B2 and use kbhit(GPS)) function before
fgetc(GPS)) as stated dyeatman.
If this not solve your problem, post your code, headers and compiler version.
Best wishes,
Humberto
runtime
Here is the code I'm using
PostPosted: Sun Aug 29, 2004 10:00 am     Reply with quote
// Nmea is pin B2
// GetPosition function reads $GPRMS sentence and buffers only relevant info, I need a way to get out of GetPosition if GPS not present...
#use rs232(baud=4800,rcv=Nmea,invert,stream=GPS)
#use rs232(baud=4800,xmit=MOut,rcv=MIn,stream=MODEM)
#use rs232(baud=4800,xmit=PCOut,invert,stream=PC) // RS232 to PC
// Function GetPosition // Parse $GPRMC
void GetPosition(void)
start: while (v != 'G') v=fgetc(GPS); // Finds the GPRMC sentence
v = fgetc(GPS);
if (v != 'P') goto start;
v = fgetc(GPS);
if (v != 'R') goto start;
v = fgetc(GPS);
if (v != 'M') goto start;
v = fgetc(GPS);
if (v != 'C') goto start;
fpoint = False; // first point found?
comma = 0; // Count comma chars
status = 0; // Build status bit
i = 0; // Buffer the GPRMC sentence
do {
v = fgetc(GPS);
if (v == ',') comma++;
if (comma == 6) v = '*'; // final marker
if ((v == '.') && (!fpoint)) { // discard .999 in time field
fpoint = True;
v = fgetc(GPS);
v = fgetc(GPS);
v = fgetc(GPS);
v = fgetc(GPS);
if (v == 'A'){ // Check for svs
sat = True;
if (firstpos) {
firstpos = False;
seconds = StoreInt - 1;
output_high(Valid);
bit_set(status,2);
v = fgetc(GPS); // Discard A,
v = fgetc(GPS);
else if (v == 'V') {
sat = False;
if (!input(Valid))(output_high(Valid)); // Flash Valid GPS led if not valid
else (output_low(Valid));
v = fgetc(GPS); // Discard V,
v = fgetc(GPS);
if (v == 'S') bit_set(status,3); // Build status bit
if (v == 'E') bit_set(status,4);
if ((v == 'N') || (v == 'S') || (v == 'W') || (v == 'E')) { // Discard N,S,W,E,
v = fgetc(GPS);
v = fgetc(GPS);
buf[i] = v; // Fill buffer
i++;
if (i == (MAXBUF - 2)) break;
} while (v != '*');
if (!input(Panic)) { // Check panic btn condition
remote = True;
if (!GPRSStarted && !LineOpen) BaseCall = True;
if (!input(Door)) { // Check Doors
DoorS = True;
if (!GPRSStarted && !LineOpen && !AckDoor) BaseCall = True;
else AckDoor = False;
if (remote) bit_set(status,0); // Panic bit
if (DoorS) bit_set(status,5); // Door sensor
if (!read_eeprom(12)) bit_set(status,1); // Engine Off bit
if (bit_test(status,0) && (!logP)) { // Log Panic On
logP = True;
ZeroStore = False;
if (!bit_test(status,0) && (logP)) { // Log Panic Off
logP = False;
ZeroStore = False;
if (bit_test(status,5) && (!logD)) { // Log Door Open
logD = True;
ZeroStore = False;
if (!bit_test(status,5) && (logP)) { // Log Door Close
logD = False;
ZeroStore = False;
status = status + 33;
zip(); // Compress buffer
Why not try it this way?
PostPosted: Sun Aug 29, 2004 5:56 pm     Reply with quote
A much better (cleaner) approach would be something like this:
#define bkbhit (next_in!=next_out)
// This routine automatically fetches and stores incoming
// chars in buffer. I would call it multiple times in main to
// make sure you dont miss any chars (depending on
// how long your main code is of course).
void Checkfordata()
{// get char and put into a circular buffer
         RXbuff[next_in] = fgetc();
          t = next_in;  //save current buffer pointer
// get next open position in recv buffer
        next_in = (next_in + 1) % BUFFER_LEN;
        if (next_in == next_out)  // is it full?
           next_in = t;  // yes!! restore old position
 } // end of CheckforData routine
// **** Start of main background loop *****
While kbhit()
     CheckforData();
// call this routine in Main() to check for something in the buffer
if (bkbhit)  // if begin and end are not the same, there must be
                //something there to get
        c = Rxbuff[next_out];  // so get it
        next_out = (next_out + 1) % BUFFER_LEN;  // update pointer
While kbhit()
     CheckforData();
Here you process your incoming data in the main loop. Use flags to keep track of where you are in the process.
While kbhit()
     CheckforData();
etc...
Just a suggestion that I thought might be useful.... :-)
