lcd_putc() CCS driver question
alexbilo
PostPosted: Sun Aug 22, 2004 2:17 pm     Reply with quote
I'm setting up a 4x20 LCD display on a pic18f452. Since I experiment strange problems (part of lines disappearing, characters replaced by others), I'm looking more closely to the CCS lcd420 driver (the one I use).
Here's my question :
void lcd_putc( char c) {
   switch (c) {
     case '\f'   : lcd_send_byte(0,1);
                   lcdline=1;
     case '\n'   : lcd_gotoxy(1,++lcdline);  break;
     case '\b'   : lcd_send_byte(0,0x10);    break;
     default     : lcd_send_byte(1,c);       break;
Can someone explain me how this function is supposed to work with statements as :
lcd_putc("Hello world!");
or
lcd_putc("Hello\n");
As I see it, this function is supposed to accept only single characters, not entire strings?
Thanks for your help,
Alex
PostPosted: Sun Aug 22, 2004 2:41 pm     Reply with quote
not entire strings?
From the CCS manual:
A (non-standard) feature has been added to the compiler to help get
around the problems created by the fact that pointers cannot be created
to constant strings. A function that has one CHAR parameter will accept
a constant string where it is called. The compiler will generate a loop that
will call the function once for each character in the string.
alexbilo
PostPosted: Sun Aug 22, 2004 3:00 pm     Reply with quote
Thanks a lot for the answer, it seems that I missed it in the manual!
Unfortunately, that doesn't solve my problem Sad.
Here's a code snippet that works :
   lcd_init();
   while(1) {
      lcd_gotoxy(1,1);
      printf(lcd_putc,"tststring");
Here's one that doesn't :
   char a[10]="tststring";
   lcd_init();
   while(1) {
      lcd_gotoxy(1,1);
      printf(lcd_putc,"%s",a);
I really can't figure why... BTW, the bad code actually prints the string on the display, but it leads to very strange bugs (lines that gets printed backwards, string printed anywhere on the display, etc.) as if the program gets lost.
Any idea?
Thanks a lot
Alex
PostPosted: Sun Aug 22, 2004 3:19 pm     Reply with quote
The following test program works OK on my LCD demo board.
I used PCM vs. 3.207. What version of the compiler are you using ?
#include <16F877.H>
#use delay(clock = 4000000)
#include <lcd.c>
//char a[10]="123456789";
lcd_init();
   lcd_gotoxy(1,1);
alexbilo
PostPosted: Sun Aug 22, 2004 3:27 pm     Reply with quote
Actually, 3.187 .
Not the latest, I know... Embarassed
Alex
PostPosted: Sun Aug 22, 2004 4:13 pm     Reply with quote
I noticed you're using PCH and the 18F452, so I installed PCH 3.187
and programmed a 18F452, and it still works. But, I'm using a 8x2
LCD, and the lcd.c driver. You're using a 20x4 LCD, and the lcd420.c
driver.
I feel that you need to:
1. Closely check the LCD wiring.
2. Compare the LCD init string used in the LCD420.C driver
to the init values specified in your LCD data sheet.
Also look at the delay times required between characters
during the LCD init (as specified in the LCD data sheet).
3. Verify important details, such as using NOLVP, and
also making sure that you don't use watchdog timer
while doing a test program. You don't want to be
testing the WDT along with the LCD. Etc.
4. Make sure that when you compile a new test program,
that it actually gets programmed into the PIC. You can
see that I use two different strings in the program below.
Whenever I change the program, I change the test string.
That way, I guarantee that I don't make some dumb mistake
such as thinking that I programmed some new code into the PIC,
but didn't really do it.
Also,
A. What LCD are you using ? (Manufacturer and part number)
B. Did you modify the CCS LCD420.C driver in any way ?
#include <18F452.H>
#fuses XT, NOPROTECT, PUT, NOBROWNOUT, NOWDT, NOLVP
#include <lcd.c>
lcd_init();
   lcd_gotoxy(1,1);
alexbilo
PostPosted: Sun Aug 22, 2004 7:47 pm     Reply with quote
Done. I made sure that everything is wired properly and it is. Proof is that the display is very stable when I use the "correct" code.
I need to take a look at that. I checked the timing requirements for the actual read and write operations, though. Moreover, the driver verifies the lcd's status bit before sending new data.
Got the NOWDT and NOLVP fuses set up. Already been mistaken by such errors. Wink
I do, too, but nice thinking Smile. Experience, huh?
I use a CFAH2004A-TMI-JP from CrystalFontz. I altered the lcd420.c driver only to adapt it to D port on a pic18 (base address and set_tris_X commands). I'll look more closely at the timing and init string, though.
I'll get back to this tomorrow evening, so you'll probly hear from me by then Smile
Thanks again for the help,
Alex
alexbilo
PostPosted: Mon Aug 23, 2004 6:50 pm     Reply with quote
Ok, now...
Here's what I found :
Your code actually -does- work. Whenever I try with a longer string, though, characters start to change randomly (but not so randomly since there's always only a few of the displayed characters that aren't correct). I checked the init string - OK. I checked the timing reqs, added 50µs after the send_nibble, OK.
The strange thing is : I looked at the signals on the data pins (D4 to D7) with a scope. I found out that the signals aren't clean (the edges aren't clean and there's random spikes while at low logic level). I tried to toggle the port's pins with a simple loop and then the signals are very clean (although the lcd is powered and connected).
Strange one huh??
HELP!!! Crying or Very sad
Alex
alexbilo
PostPosted: Mon Aug 23, 2004 8:10 pm     Reply with quote
Next update :
I solved the signals problem by modifying the busy_flag reading subroutine. However, that didn't solve my problem. Whenever I try the printf function with a variable (not in each case, but in most), I get the bug. Whenever I use the printf or lcd_putc routines with constant strings, no problem.
Any1 has a link to functions that converts longs to strings so that I can avoid printf? Smile
Thanks,
Alex
PostPosted: Mon Aug 23, 2004 8:36 pm     Reply with quote
Post a small demo program that demonstrates the printf() problem.
(You don't have to post the LCD driver).
alexbilo
PostPosted: Thu Aug 26, 2004 7:10 am     Reply with quote
Back to this printf problem :
I tested two small programs that prints two lines on the lcd (so that you can test it more easily):
This one doesn't work... Both lines are displayed, but there's a glitch in the display.
#include <18F452.H>
#fuses HS, NOPROTECT, PUT, NOBROWNOUT, NOWDT, NOLVP
#use delay(clock=1000000)
#include <lcd4_v2.c>
char a[21]="----Hello_world----";
lcd_init();
   lcd_gotoxy(1,1);
   printf(lcd_putc,"----Hello_world----\n%s\n",a);
Finaly, I doubt that the printf function is guilty... Here's another one that doesn't work :
#include <18F452.H>
lcd_init();
   lcd_gotoxy(1,1);
   lcd_putc("----Hello_world----\n----Hello_world----\n");
Notice the a variable that isn't even used... But if I comment the line, that works perfectly...
Any idea? I'm banging my head into the wall...
Alex
PostPosted: Thu Aug 26, 2004 8:24 am     Reply with quote
Are you really using a 1 MHz crystal ?
I suspect you're really using a 10 MHz crystal. With that incorrect
clock speed, all the software delays created by the compiler will
be 10x faster than they should be. The LCD driver is full of delay
statements. This is probably the reason why your LCD acts in a flakey
manner.
It's also the reason why I ask people to show a complete test program.
alexbilo
PostPosted: Thu Aug 26, 2004 8:50 am     Reply with quote
I must admit that I had some hope that it would have been the error, but unfortunately not.
It was an error and I corrected it, but it didn't solve the problem.
Here's an example of what is displayed :
----Hello_worldM---
----Hello_world---*
where * is a strange character. The glitches change place on the display.
...[/quote]
Alex
alexbilo
PostPosted: Tue Aug 31, 2004 7:42 am     Reply with quote
Got it!!!
Finally, after much debugging, I found out that the RAM memory of the PIC that I used is deffective. Data that was being sent to the lcd was getting corrupted in a transfer between two memory cases.
"%?$%? deffective chips! Evil or Very Mad
Thanks to all anyway...
Alex
