valemike Guest
low power design...PIC...9V buzzer...voltage reg? |
Posted: Wed Aug 18, 2004 6:29 pm |
I need to use a 9V battery to power a piezo beeper. Looks like this 9V battery then would have to provide the voltage to my nanowatt PIC.
(If i didn't have the beeper, then i'd probably just choose two AAA 1.5 batteries and not need a voltage regulator, and be done with.) I'll be in sleep mode 99.9% of the time until a switch closes, then I sound the beeper for 2 minutes and then go back to sleep.
here's my question:
Since i'm forced to use a 9V battery, I will need a way to drop the voltage down to 2V-5.5V. An 8-pin PIC can work down to 2V.
However, I will need to drop the voltage down, and unfortunately will drain current from the battery.
The only way to do this is to use a voltage regulator which operates in the microamp range, right? Anything other form of voltage regulation, such as a clamping zener will definitely use up milliamps? |
Kenny
Posted: Wed Aug 18, 2004 7:28 pm |
Yes, a micropower voltage regulator like the MAX666 would be a good way to go. Zeners consume too much current.
http://pdfserv.maxim-ic.com/en/ds/MAX663-MAX666.pdf
You can set the voltage you want, and it also has a low battery output.
I have used them in the past successfully, but perhaps there is an even better one available now. |
valemike Guest
Posted: Wed Aug 18, 2004 10:57 pm |
Thanks for the parts suggestions guys. |
