CCS USB support problem
hillcraft
PostPosted: Wed Aug 18, 2004 4:36 am     Reply with quote
I have been using CCS with single interface, multiple endpoint HID devices with great success.
It seems that CCS is unable to support HID combination devices properly.
I am unable to get USB.C to understand 2 defferent Report descriptors associated with 2 different Interface descriptors.
Has anybody gotten combination devices such as i.e. joystick / mouse to work using CCS
Here is the code in USB.C that seems to cause the problem
void usb_copy_desc_seg_to_ep(PID_TOGGLE tgl) {
int i=0;
char c;
while ((usb_getdesc_len)&&(i<USB_MAX_EP0_PACKET_LENGTH))
switch(USB_stack_status.getdesc_type) {
case USB_GETDESC_CONFIG_TYPE:
c=USB_CONFIG_DESC[usb_getdesc_ptr];
#IF USB_HID_DEVICE
case USB_GETDESC_HIDREPORT_TYPE:
/// this bit of code in USB.C seems to be the problem
c=USB_HID_DESC[usb_getdesc_ptr];
Darren Rook
PostPosted: Wed Aug 18, 2004 6:09 am     Reply with quote
You will have to add that yourself.
hillcraft
Ok great...
PostPosted: Wed Aug 18, 2004 6:46 am     Reply with quote
Thank you for your help.....
Ok, is there anybody out there that has already 'Added it themselves'?
Darren Rook
PostPosted: Wed Aug 18, 2004 10:42 am     Reply with quote
What I meant is:
CCS does not support that feature. If you desire this feature the user will have to add it themselves. CCS provides the basic chapter 9 layer for USB. After that all additions are application specific and must be added by the user.
hillcraft
Ok fair enough, but maybe you can help me with the following
PostPosted: Wed Aug 18, 2004 12:10 pm     Reply with quote
I have managed to create a composite HID device that has the same report descriptor (for the moment) I can pass information up and down from my dev kit to the PC and back.
I am still a bit unclear about the following issues:
1. Does an endpoint link directly to a interface descriptor, what I mean is this:
Say I have 2 Interfaces with 2 endpoints each i.e. one incoming and one outgoing:
If I am to speak to the first endpoint of the second interface, would I refer to Interface 2 endpoint 1, or would I refer or would I refer to endpoint 3.
2. Can the CCS driver determine which interface endpoint data came from:
i.e will USBkbhit(2) refer to the second incoming endpoint.
The reason that I am going this route is because my USB device currently sports a RS232 line for configuration purposes (which is a real pain)
Darren Rook
PostPosted: Wed Aug 18, 2004 1:47 pm     Reply with quote
I believe (I may be wrong) that if you have 2 interfaces and 2 endpoints for each endpoint, they would look something like this:
interface 0
endpoint 01 (endpoint 1, out)
endpoint 81 (endpoint 1, in)
interface 1
endpoint 02
endpoint 82
out and in are in reference to the PC, not the PIC.
See, all four endpoints have a different address. I think if more than one endpoint has the same endpoint bad things will happen (unless they are on different configurations).
usb_kbhit(x) works for any OUT endpoints. That would be 01 or 02 in this example.
I could be wrong. Check with the discussion forum on USB.org.
