usart baudrate problems :"Baud rate out of range"
cian
PostPosted: Tue Aug 17, 2004 8:12 am     Reply with quote
I'm trying to run a PIC16LF876A from a 7,372,800Hz xtal with some rs232 code using a 115200 baudrate. Here's a snippet:
#use DELAY(clock=7372800)
<snip>
#use rs232(baud=115200, xmit=RS232_TX, rcv=RS232_RX, ERRORS)
void rs232_putc(char c){
putc(c);
When compiling I get the error:
I've tried using the BRGH1OK option but it doesn't make any difference.
AFAIK this baudrate should be fine: 7372800/(16*4) = 115200
So does anyone know what the problem is?
Compiler version 3.188 BTW
Cheers,
Cian
garyzheng
i think the baudrate is too high for CCS compiler
PostPosted: Tue Aug 17, 2004 8:58 am     Reply with quote
you should kow that the CCS compiler had some limitation, if it told you the baudrate is too high, you should limit your baudrate, that is all
Mark
PostPosted: Tue Aug 17, 2004 9:06 am     Reply with quote
Works just fine for me. Post the defines for RS232_Tx and RS232_RX. I suspect these are wrong. You should probably use the BRGH1OK option otherwise the SPBRG value will be 0. Not sure if this is valid or not.
cian
PostPosted: Tue Aug 17, 2004 9:43 am     Reply with quote
You are of course right, I mixed up some of the pins Embarassed
I'm using two pins for hardware UART and two for software, I got them reversed.
Apologies and thanks for the help,
Cian
Mark
PostPosted: Tue Aug 17, 2004 10:06 am     Reply with quote
As it turns out, even with the BRGH1OK the compiler uses a SPBRG value of 0 so I guess it is valid plus a quick look at the datasheet shows a zero value in the table Smile
