2 PWM in 16F876???
verba
2 PWM in 16F876???
PostPosted: Tue Aug 17, 2004 12:16 am     Reply with quote
In the manual and in the datasheet, specifies that 16f876 has 2 PWM (C1 and C2).
I put this in the CCS:
   setup_timer_2(T2_DIV_BY_1,9,1);              //4Mhz, 100 Khz PWM timer
   output_high(PIN_C1);                         //Init Pin C1 as output
   output_high(PIN_C2);                         //Init Pin C2 as output
   setup_ccp1(CCP_PWM);                         //Mode PWM CPP1
   setup_ccp2(CCP_PWM);                         //Mode PWM CPP2
   set_pwm1_duty(10);                           //Init PWM1 (10=100%..0=0%)
   set_pwm2_duty(10);                           //Init PWM2 (10=100%..0=0%)
Ok, this doesnīt work. Only works the PWM2 (C1) , the PWM1 (C2) is always 0.
Why? Whatīs is wrong? I canīt configurate the two PWM at same time?
Thank you very much
Kenny
PostPosted: Tue Aug 17, 2004 1:31 am     Reply with quote
It works for me (compiler version 3.188). Your arithmetic is fine.
I didn't change anything in your code. Also I tested it by sweeping the values from 0 to 10 and back to 0, all OK.
verba
Not for me
PostPosted: Tue Aug 17, 2004 3:34 am     Reply with quote
I have 3.155
Is it possible that my version doesnīt compile correctly the PWM ?
