Nested structures problem
kypec
PostPosted: Mon Aug 16, 2004 7:04 am     Reply with quote
I've found a serious bug in an access to nested structures
in PCM 3.207. This error is present there since 3.190 AFAIK.
I've already sent a bug report to CCS.
See the listing file of my simple test program and you will know what I mean:
CCS PCM C Compiler, Version 3.207, 22683               16-VIII-04 14:41
               Filename: D:\SOURCE\pokusy\test4.LST
               ROM used: 57 words (1%)
                         Largest free fragment is 2048
               RAM used: 29 (8%) at main() level
                         29 (8%) worst case
               Stack:    0 locations
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   004
0003:  NOP
....................  #opt 0
.................... #include <16F877.h>
....................  //////// Standard Header file for the PIC16F877 device ////////////////
.................... #device PIC16F877
.................... #list
.................... #device *=16 //use 16 bit pointers
.................... struct outer {
....................    int8 o1;
....................    int8 o2;
....................    int16 o3;
....................    struct inner {
....................       int8 i1;
....................       int8 i2;
....................       int16 i3;
....................    } x,y;
.................... } a,b;
.................... void load_inner(struct inner &ptr) {
....................    ptr.i1=1; //pointer is correct
000E:  MOVLW  01
000F:  MOVWF  24
0015:  MOVLW  01
0016:  MOVWF  28
....................    ptr.i2=2; //!!! WRONG pointer !!!
0010:  MOVLW  02
0011:  MOVWF  21
0017:  MOVLW  02
0018:  MOVWF  21
....................    ptr.i3=3; //!!! WRONG pointer !!!
0012:  CLRF   23
0013:  MOVLW  03
0014:  MOVWF  22
0019:  CLRF   23
001A:  MOVLW  03
001B:  MOVWF  22
.................... void load_outer(struct outer &ptr) {
....................    ptr.o1=1; //pointer is correct
001C:  MOVLW  01
001D:  MOVWF  20
002A:  MOVLW  01
002B:  MOVWF  2C
....................    ptr.o2=2; //pointer is correct
001E:  MOVLW  02
001F:  MOVWF  21
002C:  MOVLW  02
002D:  MOVWF  2D
....................    ptr.o3=3; //pointer is correct
0020:  CLRF   23
0021:  MOVLW  03
0022:  MOVWF  22
002E:  CLRF   2F
002F:  MOVLW  03
0030:  MOVWF  2E
....................    ptr.inner.i1=1; //!!! WRONG pointer !!!
0023:  MOVLW  01
0024:  MOVWF  1F
0031:  MOVLW  01
0032:  MOVWF  2B
....................    ptr.inner.i2=2; //!!! WRONG pointer !!!
0025:  MOVLW  02
0026:  MOVWF  20
0033:  MOVLW  02
0034:  MOVWF  2C
....................    ptr.inner.i3=3; //!!! WRONG pointer !!!
0027:  CLRF   22
0028:  MOVLW  03
0029:  MOVWF  21
0035:  CLRF   2E
0036:  MOVLW  03
0037:  MOVWF  2D
.................... void main(void) {
....................    load_inner(a.x);
0004:  CLRF   04
0005:  BCF    03.7
0006:  MOVLW  1F
0007:  ANDWF  03,F
0008:  BSF    03.5
0009:  BSF    1F.0
000A:  BSF    1F.1
000B:  BSF    1F.2
000C:  BCF    1F.3
000D:  BCF    03.5
....................    load_inner(a.y);
....................    load_outer(a);
....................    load_outer(b);
0038:  SLEEP
Mark
PostPosted: Mon Aug 16, 2004 8:54 am     Reply with quote
I am not sure if this line is valid
ptr.inner.i1=1;
If you are passing the addresses, I would use pointers instead. Like this:
#include <16F877.h>
struct outer
  int8 o1;
  int8 o2;
  int16 o3;
  struct inner
    int8 i1;
    int8 i2;
    int16 i3;
  }x,y;
} a,b;
void load_inner(struct inner *ptr)
  ptr->i1=1;
  ptr->i2=2;
  ptr->i3=3;
void load_outer(struct outer *ptr)
  ptr->o1=1;
  ptr->o2=2;
  ptr->o3=3;
  ptr->x.i1=4;
  ptr->x.i2=5;
  ptr->x.i3=6;
  load_inner(&a.x);
  load_inner(&a.y);
  load_outer(&a);
  load_outer(&b);
You can also use the #separate which apears to work for the way you are doing it.
#include <16F877.h>
struct outer
  int8 o1;
  int8 o2;
  int16 o3;
  struct inner
    int8 i1;
    int8 i2;
    int16 i3;
  }x,y;
} a,b;
#separate
  ptr.i1=1;
  ptr.i2=2;
  ptr.i3=3;
#separate
  ptr.o1=1;
  ptr.o2=2;
  ptr.o3=3;
  ptr.x.i1=4;
  ptr.x.i2=5;
  ptr.x.i3=6;
  ptr.y.i1=7;
  ptr.y.i2=8;
  ptr.y.i3=9;
  load_inner(a.x);
  load_inner(a.y);
  load_outer(a);
  load_outer(b);
