a Guest
| Please see my sourcecode. it is about lcd. |
Posted: Fri Aug 13, 2004 3:40 am |
this code is use for lcd 16*2 char. but when i start my program it isn't stable because sometime lcd show 1 line.sometime show 2 line. but when it show 2 line. it will show 2 line forever. but if it show 1 line. it will show 1 line forever too.
Please see my code and correct it should be. thannk you
i use lcd in mode
#define RS PIN_E0
#define RW PIN_E1
#define EN PIN_E2
and port d0-d7 is also data0-data7 of lcd too.
i think it about void init_lcd(void) procedure but i don't know. where it's not correct.
thank you for your help
#include "C:\Micropro\SourceCode_Picc\Charger\CH6.h"
#ZERO_RAM
#include<stdio.h>
#include<stdlib.h>
#include<math.h>
#include<string.h>
#define RS PIN_E0
#define RW PIN_E1
#define EN PIN_E2
#define leddison output_high(pin_c0)
#define leddisoff output_low(pin_c0)
char tmpshow[20];
int resetch1=0;
void busy_strobe(void)
OUTPUT_LOW(EN);
delay_us(1);
OUTPUT_HIGH(EN);
delay_us(1);
void write_strobe(void)
OUTPUT_HIGH(EN);
delay_us(1);
OUTPUT_LOW(EN);
delay_ms(2);
void Command(void)
OUTPUT_LOW(RS);
OUTPUT_LOW(RW);
void wait_for_lcd_ready(void)
unsigned char busy_flag;
SET_TRIS_D(0XFF); //PORTD7 INPUT;
OUTPUT_LOW(RS); //SET FOR READ BUSY;
OUTPUT_HIGH(RW); //SET FOR READ BUSY;
busy_strobe();
busy_flag=(input_d() & 0x80);
while( busy_flag == 0x80)
OUTPUT_LOW(EN);
busy_flag=(input_d()&0x80);
OUTPUT_LOW(EN);
SET_TRIS_D(0x00); //PORTD7 OUTPUT;
void clear_lcd(void)
Command();
OUTPUT_D(0x01);
write_strobe();
wait_for_lcd_ready();
void cursor_off(void)
Command();
OUTPUT_D(0x0c);
write_strobe();
void init_lcd(void)
Command();
OUTPUT_D(0x38);
write_strobe();
Command();
OUTPUT_D(0x0f);
write_strobe();
clear_lcd();
Command();
OUTPUT_D(0x02);
write_strobe();
cursor_off();
void Wchar(unsigned char char_)
OUTPUT_HIGH(RS);
OUTPUT_LOW(RW);
OUTPUT_D(char_);
write_strobe();
void gotoxy(unsigned char row,unsigned char col)
Command();
if (row==1) OUTPUT_D(0x80+col-1);
if (row==2) OUTPUT_D(0xc0+col-1);
write_strobe();
void Wcharxy(unsigned char row,unsigned char col,unsigned char data_)
gotoxy(row,col);
Wchar(data_);
void string_to_lcd(unsigned char row,unsigned char col,unsigned char *st)
unsigned char i,len;
len=strlen(st);
if (len>20) len=20;
gotoxy(row,col);
for(i=0;i<=len-1;i++)
Wchar(st[i]);
void int_to_lcd(unsigned char row,unsigned char col,int data_int)
unsigned char str[7];
sprintf(str,"%d",data_int);
string_to_lcd(row,col,str);
void long_to_lcd(unsigned char row,unsigned char col,long data_long)
sprintf(str,"%ld",data_long);
void hex_to_lcd(unsigned char row,unsigned char col,unsigned char data_hex)
unsigned char str[3];
sprintf(str,"%x",data_hex);
void float_to_lcd(unsigned char row,unsigned char col,float data_float)
sprintf(str,"%02.1f",data_float);
Posted: Fri Aug 13, 2004 5:12 am |
Port E is analog input unless you explicitly set it to NO_ANALOG.
Your output_low() and output_high() calls are never executed. |
a Guest
Posted: Fri Aug 13, 2004 7:16 am |
| i set port e is output and port d is input/output in wizard. and thank you for your answer |
