Are there same function as printf to receive data?
young
PostPosted: Thu Aug 12, 2004 6:23 am     Reply with quote
printf("data: %f %i",a, b) send data to RS232 port, on the other side, I receive the sended data as ASCII data, How I can interpret them into a float and a int data.
Mark
PostPosted: Thu Aug 12, 2004 6:36 am     Reply with quote
The C function for that would be scanf(). I am not sure if CCS has this function. You will just have to look to see.
Mark
PostPosted: Thu Aug 12, 2004 6:43 am     Reply with quote
There are also other functions to convert strings to number
atoi()
atol()
See the manual for more
Re: Are there same function as printf to receive data?
PostPosted: Thu Aug 12, 2004 6:44 am     Reply with quote
In normal C, the 'inverse' function, is sscanf. The problem is that as you will have allready found, if you look at the code sizes generated by printf, 'general purpose' functions, tend to be bulky. There have been some implementations of sscanf published in the past, but generic versions tend to be large. However if your string is in a relatively simple 'known' format (which your question suggests), then the answer is to use the standard string functions, then search the string for the character that seperates the two numbers, take the section in front of this, and use the STRTOD function to convert this to a float, then use the STRTOL or STRTOUL function on the rest of the string, to change this into a (long) integer.
young
PostPosted: Thu Aug 12, 2004 6:48 am     Reply with quote
It is nt defined in CCS, so any other ways?
Mark
PostPosted: Thu Aug 12, 2004 6:53 am     Reply with quote
Are you handling a single case or do you require a general purpose function to handle multiple cases. For a single case (or just a case) Ttelmah suggestion is the way to go. If you can afford the overhead and require multiple cases, then implement the sscanf() yourself. I have written a sscanf() for the C18 compiler. It uses variable arguments which I don't think CCS supports. I could probably change it around a bit to work with CCS but search the forum and see if someone has already posted one. If not, then maybe I'll put one in the code section.
young
PostPosted: Thu Aug 12, 2004 7:02 am     Reply with quote
Thank you Mark:
A special case solution will not be a bad idea for current use, but if you developed any general purpose function, it will be great, Waiting for your code!
young
PostPosted: Thu Aug 12, 2004 7:32 am     Reply with quote
Hi Ttelmah:
Do you have any code that separate the string into different part?
thank you
Mark
PostPosted: Thu Aug 12, 2004 7:38 am     Reply with quote
To find a string in a string CCS has a function strstr()
To break up a string based on tokens use strtok()
Mark
PostPosted: Fri Aug 13, 2004 2:12 pm     Reply with quote
Code is in the Library.
http://www.ccsinfo.com/forum/viewtopic.php?t=20225
DragonPIC
gets()
PostPosted: Tue Aug 17, 2004 2:03 pm     Reply with quote
I would use:
gets(floater);
gets(interger);
atoi(interger);
atof(floater);
