RS232, ICD, fuses
kender
RS232, ICD, fuses
PostPosted: Mon Aug 09, 2004 1:25 pm     Reply with quote
Colleagues,
I'm using ICD-U40 to program the PIC. The problem is that I don't get the RS232 output unless the ICD is attached to the PIC.
Here are my declarations:
#include <18F452.h>
// #device ICD=TRUE
#device adc=10
#use delay(clock=12800000)
#fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN, NODEBUG, LVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
What do you think is wrong?
Thanks,
Nick[/code]
Re: RS232, ICD, fuses
PostPosted: Mon Aug 09, 2004 2:50 pm     Reply with quote
kender wrote:
Colleagues,
#include <18F452.h>
// #device ICD=TRUE
#device adc=10
Thanks,
Nick[/code]
Given you are enabling LVP, what are you connecting to the control line, to ensure it floats to a disabled state?. RB5, must be pulled down (If you enable internal pullups, you have to clear bit 5 of the TRIS register, to turn off the pullup on this pin), or the chip won't run.
DisgruntledPostalWorker
PostPosted: Wed Aug 11, 2004 9:17 am     Reply with quote
I had a similar problem with the debug environment. If I was debugging, all was well. If I was running in standalone mode, I couldn't get anything in the UART. After 12 hours of experimenting, I found that the #USE RS232 calls create an interrupt each time they're used. In the debug environment, the interrupts aren't seen, so it works. In standalone mode, the #USE interrupt blocked my UART interrupt and I never received anything. The fix: stop using #USE each time I switched ports. Put all your #USE statements at the top of the file ONCE only, and identify them as streams. Then, use fprintf to print to streams, without using the #USE statments in running code. It was the only workaround I could find.
Any others with this problem?
kender
PostPosted: Wed Aug 11, 2004 9:21 am     Reply with quote
The solution was in hardware in my case. RS232 had poor ground connection, so when I was attaching the ICD, it was creating an additional ground connection.
Nick
