Bootloader for PIC16F876A
Arnaud
PostPosted: Mon Aug 09, 2004 5:21 am     Reply with quote
I am working on a PIC16F876A and I would like to use a bootloader for it. However, the loader.c I have with my compiler (v 3.150) does only work with the PIC16F876. Does a bootloader exist for the A extension ?
Thanks you
Regards
Mark
PostPosted: Mon Aug 09, 2004 6:00 am     Reply with quote
Should work for both.
Sorry
PostPosted: Mon Aug 09, 2004 6:28 am     Reply with quote
Mark
PostPosted: Mon Aug 09, 2004 6:44 am     Reply with quote
CCS should have any issues with writing fixed, if there ever were any. The compiler knows which chip you are using (provided you specify the 16F876A) and should handle it correctly. Try it and see.
Arnaud
PostPosted: Mon Aug 09, 2004 8:48 am     Reply with quote
Hi Mark,
Thank you for your answer. I tried without success tu use loader.c. I programmed my PIC successfully. But under hyperterm I tried to send hex file but nothing happened. I search on this forum how to configure hyperterm and how to send hex file but I did not find any answer.
Could you help me please?
Thank you
Regards
Mark
PostPosted: Mon Aug 09, 2004 8:52 am     Reply with quote
Post you code showing how you implemented it. Also see this:
//// The LOADER.C will take an Intel 8-bit Hex file over RS232 ////
//// and modify the flash program memory with the new code. ////
//// After each good line, the loader sends an ACK character. The ////
//// driver uses XON/XOFF flow control. Also, any buffer on the PC ////
//// UART must be turned off, or to its lowest setting, otherwise it////
//// will miss data. ////
//// A program such as Hyper-Term may be used to simply transmit the////
//// .HEX file output from the compiler. ////
Arnaud
PostPosted: Mon Aug 09, 2004 9:00 am     Reply with quote
Thank you Marc for your answer
I did not change anything to the CCS loader.c and ex_load.c files excepted the #include <16f876a.h>.
I configured my hyperterm with XON/XOFF 1 stop bit and no parity. I also unchecked FIFO buffers in the COM properties.
I tried "send a file" and "send a text file" with hyperterm and it says that the target is not responding...
So I am a little confused...
What do you think I did wrong
Regards
Mark
PostPosted: Mon Aug 09, 2004 10:16 am     Reply with quote
How did you get it into bootloader mode?
Did you see anything on the Hyperterminal screen?
What board are you using?
Is the circuit good?
Mark
PostPosted: Mon Aug 09, 2004 11:50 am     Reply with quote
I used ex_bootloader.c and ex_bootload.c with the 16F876A with no problems.
Arnaud
PostPosted: Mon Aug 09, 2004 10:51 pm     Reply with quote
I do not have these two files. I only have loader.c eand ex_load.c
Mark
PostPosted: Tue Aug 10, 2004 6:04 am     Reply with quote
Since this is just an example of how to use one of their driver files, I'll post the code. If you are missing any driver files, then contact CCS for them.
ex_bootload.c
////                      EX_BOOTLOAD.C                                ////
////  This program is an example application program that can be       ////
////  be loaded, recompiled and reloaded by a stand alone bootloader.  ////
////  Before loading this program the bootloader (ex_bootloader.c)     ////
////  must be compiled and loaded into the target chip.                ////
////  Use an RS232 link and the SIOW.EXE program to load this HEX file ////
////  into the target chip.  See ex_bootloader.c for more information. ////
////  This example will work with the PCM and PCH compilers.  The      ////
////  following conditional compilation lines are used to include a    ////
////  valid device for each compiler.  Change the device, clock and    ////
////  RS232 pins for your hardware if needed.                          ////
////        (C) Copyright 1996,2004 Custom Computer Services           ////
//// This source code may only be used by licensed users of the CCS    ////
//// C compiler.  This source code may only be distributed to other    ////
//// licensed users of the CCS C compiler.  No other use,              ////
//// reproduction or distribution is permitted without written         ////
//// permission.  Derivative programs created using this software      ////
//// in object code form are not restricted in any way.                ////
#if defined(__PCM__)
#include <16F877.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
#elif defined(__PCH__)
#include <18F452.h>
#endif
#include <bootloader.h>
void main(void) {
   int i=0;
   printf("\r\nApplication program version 1.00 \r\n");
     printf("%u ",++i);
ex_bootloader.c
////                      EX_BOOTLOADER.C                              ////
////  This program is an example stand alone bootloader.               ////
////  This program must be loaded into a target chip using a device    ////
////  programmer.  Afterwards this program may be used to load new     ////
////  versions of the application program.                             ////
////  This bootloader is designed to detect pin B5 low on reset.  It   ////
////  will then use the RS232 link to download a new program.          ////
////  Otherwise the application program is started.                    ////
////  Use an RS232 link and the SIOW.EXE program to load a new HEX     ////
////  file into the target chip.                                       ////
#include <16F877.h>
#include <18F452.h>
#endif
#define _bootloader
#include <loader.c>
 #org LOADER_END+1,LOADER_END+10
 #org LOADER_END+2,LOADER_END+20
#endif
void application(void) {
  while(TRUE);
#if defined(__PCH__)
#org 0x40,0x7F
#else
#org 0x20,0x3F
#endif
void main(void) {
   if(!input(PIN_B5))
      load_program();
   application();
#ORG default
   #int_global
   void isr(void) {
     #asm
       goto LOADER_END+5
     #endasm
   #int_global
   void isr(void) {
     #asm
       goto LOADER_END+7
       nop
       nop
       nop
       nop
       nop
       nop
       goto LOADER_END+0x17
     #endasm
#endif
bootloader.h
////                       BOOTLOADER.H                                ////
////  This include file must be included by any application loaded     ////
////  by the example bootloader (ex_bootloader.c).                     ////
////  The directives in this file relocate the reset and interrupt     ////
////  vectors as well as reserving space for the bootloader.           ////
////  LOADER_END and LOADER_SIZE may need to be adjusted for a         ////
////  specific chip and bootloader.                                    ////
   #define LOADER_END   0x1FF
   #define LOADER_SIZE   0x1BF
   #define LOADER_END   0x4FF
   #define LOADER_SIZE   0x3FF
#endif
#ifndef _bootloader
   #build(reset=LOADER_END+1, interrupt=LOADER_END+5)
   #build(reset=LOADER_END+2, interrupt=LOADER_END+8)
#endif
#org 0, LOADER_END {}
#endif
bdavis
PostPosted: Tue Aug 10, 2004 10:55 pm     Reply with quote
Arnaud - did you try siow.exe ? Is pin B5 tied low?
Mark - Do you typically just load only the bootloader then later load the application via RS-232? Seems like it could be done also loading bootloader and application at the same time, and later (if FW upgrade), reload the FW.
Is there any good source of info on the bootloader? I was thinking of printing out a string via RS-232, and if the user replied with the correct response in a few seconds, then it would wait for a file to be downloaded or something. The way the example code looks, if RB5 is low, then your app never runs, only the bootloader.
I think CCS should give you and a few others free tools for life for all the posts you do, and all the help you give others Very Happy
I plan on starting to get a PIC bootloader running in the next week or so, so any other ideas, or sources of info would be appreciated.
Thanks,
-Brad
Mark
PostPosted: Wed Aug 11, 2004 5:50 am     Reply with quote
I don't use CCS's bootloader. Kinda simple not many features. I used the 16F/18F one that Microchip has an App note on. Small, seems to work well. They had a VB app to program it which they give you source code for which of course I changed to suit my needs and make it a bit easier for the novice to use.
bdavis
PostPosted: Wed Aug 11, 2004 1:29 pm     Reply with quote
I looked at the appnote AN851, and its all assembler - did you port it to CCS 'C', or are you keeping it in assembler? I guess it wouldn't hurt to just keep it as assembler... I would like to later be able to concatinate the bootloader with my firmware, so I only have to load it once, but the location and everything like that seems to depend upon the bootloader.
Mark
PostPosted: Wed Aug 11, 2004 5:46 pm     Reply with quote
Embarassed I use the C18 and just included the asm file Wink I did modify it just a little. One of my products the bootloader code will actually drive an LCD as a visual to the user. It also had to drive some 74HC165's to read some keys on a keypad. It was still under 0x300 in size. You could probably port it the CCS's asm.
