i'm using the pic18f458 and wanted to use the int2-pin (rb2) for external interrupt. but there is no interrupt constant INT_EXT2 defined in the 18f458.h (only INT_EXT and INT_EXT1).
so how can i use the external interrupt 2 in my code?
thanks!
cya
i2c2k
Mark
Posted: Fri Aug 06, 2004 5:41 am
You can always use the PIC's registers to set things up. Refer to the section in the datasheet for which registers to set.
Mark
