When I put a function call in the #int_ext, out of rom?
Nick
PostPosted: Wed Aug 04, 2004 9:28 am     Reply with quote
When I put a function call in #int_ext I get an out of rom error. The function I'm calling reads the eeprom and reads the rtc clock. Any know what I'm doing wrong? I can do a printf function call.
Nick
garyzheng
give out some part of code for #int_ext:)
PostPosted: Wed Aug 04, 2004 9:38 am     Reply with quote
Nick
PostPosted: Wed Aug 04, 2004 9:45 am     Reply with quote
the actually code is not on this computer, but if its needed I can post it.
basically this is it
#int_ext
void detect_rb_change()
checkTimers();
rnielsen
PostPosted: Wed Aug 04, 2004 10:07 am     Reply with quote
If your application is not timing critical I would simply set a bit, in the interrupt service routine, that would enable the function to be called in the main body.
Nick
PostPosted: Wed Aug 04, 2004 10:09 am     Reply with quote
great idea! Thanks bud!
valemike
PostPosted: Wed Aug 04, 2004 11:16 am     Reply with quote
How much remaining space in ROM did you have if you don't call that particular function in the ISR?
-Mike
