I believe I turned on the SQW with the binary 10010011 / 0x93. Someone in a previous post said I could wake up every second using this OUT/SQW, but it seems it is will waking up many times a second since its a SQW at 32hz.
Wonder if I should do something like an pic internal timer and just sleep and just wake up once a minute.
I as you can tell I'm new to pics. Here is a dumb question. Can I tell the pic to sleep for 50 seconds then wake up? I see that I can get it to sleep and wake up on an interupt RB0 attached to the RTC, but that is still way more awake time than I need.
Nick
Mark
Posted: Wed Aug 04, 2004 10:40 am
Drive timer0 and wake up on overflow. You can preload the timer value to set the number of seconds.
