newguy
t6963c graphical lcd drivers |
Posted: Mon Jul 19, 2004 10:26 am |
Edit (update Feb 11 2005):
Just got this message from Treitmey:
Quote: | Found that in the read of data, some of my hardware requires that
that an #asm nop #endasm is needed before latching the data.
Some of the documentation also states wait 150nS. I figured 1 noop is enough.
Can you update you listing in the code library as such.
for read and readbyteauto. |
Done. Thanks Treitmey!
Here's some code that Treitmey originally posted some time ago - I modified it a bit. It's a complete set of drivers for a graphical lcd equipped with the toshiba T6963C controller.
The hookup is really easy - you only need 8 data lines, and an additional 4 control lines: /WR, /RD, C/D (command/data), and /RESET. There is a document regarding the 6963 chip somewhere on the 'net that says that you also need to hook up the /CE signal, but you don't. Just tie it to ground, along with the FS pin (font select), which will give you 8x8 sized spaces for characters (the characters are always 5x7, regardless of the state of the FS pin).
The only function of the display that I haven't implemented is the user-defined characters in the text mode.
Most of the 240x64 displays come with 8k RAM, which is enough for about 4 full unique displays. To quickly switch between these displays, just set the graphics home to the base address of the new screen/picture.
Anyway, here's some sample code (18F452 @ 4 MHz) that I cut & pasted from a project that I'm currently working on. That's the reason why the interrupts are enabled, but there are no interrupt routines.
Code: | #include <18F452.h>
#device *=16
#device adc=10
#use delay(clock=4000000,RESTART_WDT)
#fuses XT, BROWNOUT, BORV27, PUT, STVREN, NOLVP
//// This file contains drivers for using a Tosiba T6963C controller ////
//// in parallel/8080(intel) mode. The T6963C is 240 pixels across ////
//// and 64 pixels down. The driver treats the upper left pixel 0,0 ////
//// Connections are as follows: ////
//// /WR - - C4 ////
//// /RD - - C5 ////
//// C//D- - C6 ////
//// /RST- - C7 ////
//// DATA0-7 PORTD0-7 ////
//// LCD's FS is tied low (FS = 0 is 8x8 font) ////
// 240 x 64 in the 8x8 font mode means that 30 characters across by
// 8 rows of characters may be displayed
#define set_tris_lcd(x) set_tris_d(x)
//TRIS DataBus=x, note:control bus (PORTC) always outputs
const int16 TextHome = 0x0780;
const int8 TextArea = 0x001E; // how many bytes before a new line
const int16 GraphicsHome = 0x0000;
const int8 GraphicsArea = 0x001E; // how many bytes before a new line
const int8 AutoModeWrite = 0xB0;
const int8 AutoModeRead = 0xB1;
const int8 AutoModeReset = 0xB2;
const int8 LCDModeSet = 0x80; // send this OR'd with the following
const int8 LCDMode_OR = 0b0000;
const int8 LCDMode_XOR = 0b0001;
const int8 LCDMode_AND = 0b0010;
const int8 LCDMode_TA = 0b0100; // TEXT ATTRIBUTE mode.
const int8 LCDMode_RAM = 0b1000; // 1=CG RAM, 0=internal CG ROM
const int8 LCDSetCursorPtr = 0x21; // cursor address
const int8 LCDSetCursorSize = 0xA0; // 1 line cursor
const int8 LCDDispMode = 0x90; // send this OR'd with the following
const int8 LCDDisp_BLK = 0b0001;
const int8 LCDDisp_CUR = 0b0010;
const int8 LCDDisp_TXT = 0b0100;
const int8 LCDDisp_GRH = 0b1000;
struct lcd_pin_def
BOOLEAN unused1; // C0
BOOLEAN unused2; // C1
BOOLEAN unused3; // C2
BOOLEAN unused4; // C3
BOOLEAN w_bar; // C4 Write bar active low
BOOLEAN r_bar; // C5 Read bar active low
BOOLEAN cd; // C6 Command/Data BAR 1=command 0=data
BOOLEAN reset_bar; // C7 Reset active low
int data : 8; // PortD=Data bus
struct lcd_pin_def LCD;
#byte LCD = 0xf82 // portC address on 18F452
int glcd_ReadByte(void);
void glcd_WriteByte(int1 cd, int data);
void glcd_WriteByteAuto(int data);
void glcd_WriteCmd2(int16 data, int cmd);
void glcd_WriteCmd1(int data, int cmd);
void glcd_gotoxy(int x, int y, int1 text);
void glcd_init(void) {
int16 counter;
set_tris_lcd(0xff); //TRIS DATA bus,note:control bus always outputs
LCD.w_bar = 1; // INITIAL STATES OF CONTROL PINS
LCD.r_bar = 1; //
LCD.cd = 1; // command
LCD.reset_bar = 0; // perform a reset
delay_us(10); // delay for a reset
LCD.reset_bar = 1; // run
// Set up the graphics and text areas
glcd_WriteCmd2(TextHome, 0x40);
glcd_WriteCmd2(TextArea, 0x41);
glcd_WriteCmd2(GraphicsHome, 0x42);
glcd_WriteCmd2(GraphicsArea, 0x43);
// set address to 0
glcd_WriteCmd2(0x0000, 0x24);
// Clear all RAM of LCD (8k)
glcd_WriteByte(1, AutoModeWrite);
for (counter = 0; counter < 0x1fff; counter++)
glcd_WriteByteAuto(0); // fill everything with zeros
glcd_WriteByte(1, AutoModeReset);
int status = 0, temp = 0;
set_tris_lcd(0xff);
LCD.w_bar = 1;
LCD.r_bar= 1;
LCD.cd = 1;//defaults
while (status != 0x03) { // is LCD busy?
LCD.r_bar= 0;
temp = LCD.data;
LCD.r_bar = 1;
status = temp & 0x03;
set_tris_lcd(0x00); // All outputs
LCD.cd = cd; // Command/Data bar
LCD.data = data;
LCD.r_bar = 1; // not read
LCD.w_bar = 0; // write
LCD.w_bar = 1; // release
int status = 0, temp = 0; // status bits ARE DIFFERENT BITS THAN NORMAL
set_tris_lcd(0xff);
LCD.w_bar = 1;
LCD.r_bar = 1;
LCD.cd = 1; // defaults
while (status != 0x08) { // is LCD busy?
LCD.r_bar = 0;
temp = LCD.data;
LCD.r_bar = 1;
status = temp & 0x08;
LCD.cd = 0; // This is always data, cd=0
LCD.data = data; // Put data on data bus
glcd_WriteByte(0, data);
glcd_WriteByte(1, cmd);
glcd_WriteByte(0, data & 0xff);
glcd_WriteByte(0, data>>8);
int data = 0, status = 0, temp = 0;
set_tris_lcd(0xff);
LCD.w_bar = 1;
LCD.r_bar = 1;
#asm nop #endasm
LCD.r_bar = 0;
temp = LCD.data;
LCD.r_bar = 1;
LCD.cd = 0; // Command/Data bar
LCD.r_bar = 0; // read
#asm nop #endasm // THIS PAUSE IS VERY NESSESARY !!!//
data = LCD.data;
LCD.r_bar = 1;
LCD.cd = 1;
return data; // Return the read data
void glcd_putc(char c) {
glcd_WriteCmd1(c - 0x20, 0xc0);
void glcd_gotoxy(int x, int y, int1 text) { // sets memory location to screen location x, y
// location 1,1 is upper left corner; text = 1 (text area), text = 0 (graphics area)
int16 location, home;
int line;
if (!text) {
home = GraphicsHome;
line = GraphicsArea;
else {
home = TextHome;
line = TextArea;
location = home + (((int16)y - 1) * line) + x - 1;
glcd_WriteCmd2(location, 0x24);
#use fast_io(D)
setup_adc_ports(ALL_ANALOG);
setup_adc(ADC_CLOCK_DIV_8);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_ON);
setup_timer_0(RTCC_DIV_256|RTCC_8_bit);
setup_timer_1(T1_DISABLED);
enable_interrupts(INT_RTCC);
enable_interrupts(INT_AD);
enable_interrupts(INT_RB);
enable_interrupts(global);
set_tris_c(0x00); // graphic lcd control lines all output
glcd_init();
glcd_WriteByte(1, (LCDModeSet|LCDMode_XOR));
glcd_WriteByte(1, (LCDDispMode|LCDDisp_TXT|LCDDisp_GRH));
The above code will initialize the graphic lcd. If you wanted to display "Hi there" beginning at screen location column 4, row 3, then these two commands will do that:
Code: | glcd_gotoxy(4,3,1); // 1 = text area of memory; note that there are only
// 8 rows of text possible
glcd_putc("Hi there"); |
If you wanted to create an 8 pixel x 8 pixel black square with the upper left corner of the square located at 9 pixels in from the left, and 43 pixels down from the top, then this code will do that:
Code: | int n;
for (n = 0; n< 8; n++) {
glcd_gotoxy(2,43+n,0); // 0 = graphics memory area; note that there
// are still 30 columns (30 x 8 pixels = 240), but now there are now 64
// rows so pixel location 9,43 translates into column 2, row 43. A little
// confusing, I know, but that's the way it works.
glcd_WriteCmd1(0xff,0xc0);
The Puma
Joined: 23 Apr 2004 Posts: 227 Location: The Netherlands
newguy
changes for 16f877 |
Posted: Tue Jul 20, 2004 11:46 am |
Assuming that your graphical lcd also uses the toshiba controller, there's really only 2 things you need to change:
1. Where it says Code: | #byte LCD = 0xf82 // portC address on 18F452 | , change the address from 0xf82 to 7. The place to find this is in Microchip's datasheet for the 16F877 - look for "Special Function Registers" in the datasheet's table of contents.
2. Where it says Code: | const int8 TextArea = 0x001e; // how many bytes before a new line | , change this to 0x0010, which would be the number of bytes wide your screen is (0x0010 = 16 = 128 dots/8 dots/byte). Also change the GraphicsArea to 0x0010 as well. |
William H. Conley III
Posted: Thu Jul 29, 2004 2:47 pm |
do you need the "#device *=16" ? |
newguy
Posted: Thu Jul 29, 2004 3:19 pm |
No, you don't need the #device *=16. |
xmen
Posted: Fri Jul 30, 2004 9:10 pm |
Hello newguy:
May you put some example to draw a box or a line, with your routines ?
I don't understand your example to draw a black square.
Also, if may you put some example to set ON and set OFF a specific pixel.
I don't see in your source code, function to clear screen.
Kind regards. |
treitmey
Posted: Mon Aug 02, 2004 10:51 am |
This is my clear screen routine
// Purpose: Clears LCD RAM
void glcd_clr(int16 location,int16 size)
////fprintf(DEBUG,"loc=%lu size=%lu\n\r",location,size);
// look very simular to the init,... doesn't it. : )
glcd_WriteCmd2(location,LCDSetPtr);
glcd_WriteCmd0(AutoModeWrite);
for (;size;size--)
glcd_WriteByteAuto(0x00);//clear ram
glcd_WriteCmd0(AutoModeReset);
and get the location using a define
#define LCDTxtAdr(s,x,y) 0x780+(240*s)+(AreaSet_T*y)+x
//that is the screen,x position , y position
so the call looks like
glcd_clr(LCDTxtAdr(SCRN0,0,0),CharPerScn);
Hope this helps |
treitmey
Posted: Mon Aug 02, 2004 10:54 am |
by the way,.. I use this define to print text all the time.
glcd_WriteCmd2(LCDTxtAdr(SCRN0,2,2),LCDSetPtr);//(screen,x,y)
printf(glcd_putc, "ADDRESS=%u",MyAddr);
ganeshbook
GDM128128A |
Posted: Sat Sep 09, 2006 4:09 am |
This is ganesh. I am using 128 * 128 graphical display(t6963c) and it was succesfully initialised. But i cant able to change the font size from 5*8 to 8*8. What should i do.
Can U help me.
Thanking U. |
treitmey
Posted: Tue Sep 12, 2006 7:38 am |
On my board this is done with a jumper to the FS pin on the header.
From Hantronix AppNote.
A zero on FS will place a 5x7 pixel character in a 8x8 field.((30 char/line))
A one on FS will place a 5x7 pixel character in a 6x8 field.
((240/6=40 char /line))
NOTE THAT THE FONT IS STILL 5x7...It is just the field that changes |
zhiling0229
Posted: Thu Sep 14, 2006 9:52 am |
hi,
just want to know if I'm using Port A.0 as C/D, A.1 as read, A.2 as write, A3 as reset and Port B as data bus, what instruction should i change?
I'm using 16f877a
Thanks |
treitmey
Posted: Thu Sep 14, 2006 1:26 pm |
Try the
and related tris.
Note also that port a is probably "open collector" |
zhiling0229
Posted: Sat Sep 16, 2006 9:06 am |
Hi guys,
I just tested the code and it works
But I'm using a 240x120 display
I was wondering what value should I change for 1FFF to clear all the ram value on the screen :
glcd_WriteByte(1, AutoModeReset); |
treitmey
Posted: Mon Sep 18, 2006 8:13 am |
Just so you know. You should ask questions in main forum. NOT here in the code library.
1 bit of memory for every 1 bit on screen. so...
I think its just 240*120=0x7080=28800
Will that nuber fit in the variable size alloted? |
newguy
Posted: Mon Sep 18, 2006 8:58 am |
zhiling0229 wrote: | Hi guys,
I'm a little confused. You say it works, yet you ask about clearing a 240x120 display.
The t6963c controller has 8k of RAM built-in. 8k is enough for 65,536 individual pixels (8,192 bytes x 8 pixels/byte), and a 240 x 120 display only has 28,800. The routine, as it stands, should clear the display without any modifications.
However, if you have a display with TWO t6963c controllers, it will not. |
