Hi, just browse through types of optocoupler and a bit confused why some of the optocouplers need 6 pins(4basic pins + 1 base and one NC)(e.g. CN17), and some other (e.g. SFH615A) only needs 4 pins.
Any additional advantage by using 6 pins configuration? Because I found it is quite wasting space. If we can use only 4 pins type to solve same problem.
REgards: Einly, _________________ Einly
SherpaDoug
Posted: Tue Jul 27, 2004 8:48 am
The base pin of a six pin optocoupler is rarely used. It can be used for noise filtering, for temperature compensation, or for injecting a test signal to simulate a real input.
Four pins is standard for commercial digital use. _________________ The search for better is endless. Instead simply find very good and get the job done.
Posted: Tue Jul 27, 2004 9:37 am
Or for speed up the transmission speed up to 3-5 times faster. Using a 220kohm-1Mohm resistor helps to discarge the base-emitter capacity.
