Newbie Question: 16F877 - Flashing LEDs
rtracy
PostPosted: Tue Jul 27, 2004 8:10 am     Reply with quote
I'm using a 16F877 on Microchip's PICDEM 2 PLUS board. I wrote some simple code to flash the LEDs built onto the demo board. The problem is that no matter what I try RB3 will not go high. RB0 flashes, RB1 flashes, RB2 flashes but RB3 will not activate. I even measured at the 16F877's pin to be sure there wasn't a problem with the demo board.
Using the CCS project wizard, I set all of RB to output and double checked all configuration bits. I'm using the latest versions of the CCS compilers and the latest version of MPLAB IDE (6.60).
Thanks for any advice.
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
  while (TRUE) {
    output_high(PIN_B0);
    output_low(PIN_B0);
    output_high(PIN_B1);
    output_low(PIN_B1);
    output_high(PIN_B2);
    output_low(PIN_B2);
    output_high(PIN_B3);
    output_low(PIN_B3);
CCS PCM C Compiler, Version 3.206, 24798               27-Jul-04 08:48
               Filename: C:\Program Files\PICC\Examples\Rob's Test Project 2.LST
               ROM used: 174 words (2%)
                         Largest free fragment is 2048
               RAM used: 7 (4%) at main() level
                         8 (5%) worst case
               Stack:    1 locations
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   019
0003:  NOP
....................  #include "C:\Program Files\PICC\Examples\Rob's Test Project 2.h"
....................  #include <16F877.h>
....................  //////// Standard Header file for the PIC16F877 device ////////////////
.................... #device PIC16F877
.................... #list
.................... #device adc=8
.................... #use delay(clock=4000000)
0004:  MOVLW  22
0005:  MOVWF  04
0006:  MOVF   00,W
0007:  BTFSC  03.2
0008:  GOTO   018
0009:  MOVLW  01
000A:  MOVWF  78
000B:  CLRF   77
000C:  DECFSZ 77,F
000D:  GOTO   00C
000E:  DECFSZ 78,F
000F:  GOTO   00B
0010:  MOVLW  4A
0011:  MOVWF  77
0012:  DECFSZ 77,F
0013:  GOTO   012
0014:  NOP
0015:  NOP
0016:  DECFSZ 00,F
0017:  GOTO   009
0018:  RETLW  00
.................... #fuses NOWDT,XT, NOPUT, NOPROTECT, NOBROWNOUT, LVP, NOCPD, NOWRT, NODEBUG
.................... #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9,restart_wdt)
0019:  CLRF   04
001A:  MOVLW  1F
001B:  ANDWF  03,F
001C:  BSF    03.5
001D:  BSF    1F.0
001E:  BSF    1F.1
001F:  BSF    1F.2
0020:  BCF    1F.3
0021:  MOVLW  19
0022:  MOVWF  19
0023:  MOVLW  66
0024:  MOVWF  18
0025:  MOVLW  D0
0026:  BCF    03.5
0027:  MOVWF  18
....................    setup_adc_ports(NO_ANALOGS);
002A:  BSF    03.5
002B:  BSF    1F.0
002C:  BSF    1F.1
002D:  BSF    1F.2
002E:  BCF    1F.3
....................    setup_adc(ADC_OFF);
002F:  BCF    03.5
0030:  BCF    1F.0
....................    setup_psp(PSP_DISABLED);
0031:  BSF    03.5
0032:  BCF    09.4
....................    setup_spi(FALSE);
0028:  MOVLW  FF
0029:  MOVWF  20
0033:  BCF    03.5
0034:  BCF    14.5
0035:  BCF    20.5
0036:  MOVF   20,W
0037:  BSF    03.5
0038:  MOVWF  07
0039:  BCF    03.5
003A:  BSF    20.4
003B:  MOVF   20,W
003C:  BSF    03.5
003D:  MOVWF  07
003E:  BCF    03.5
003F:  BCF    20.3
0040:  MOVF   20,W
0041:  BSF    03.5
0042:  MOVWF  07
0043:  MOVLW  00
0044:  BCF    03.5
0045:  MOVWF  14
0046:  BSF    03.5
0047:  MOVWF  14
....................    setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
0048:  MOVF   01,W
0049:  ANDLW  C0
004A:  IORLW  08
004B:  MOVWF  01
....................    setup_timer_1(T1_DISABLED);
004C:  BCF    03.5
004D:  CLRF   10
....................    setup_timer_2(T2_DISABLED,0,1);
004E:  MOVLW  00
004F:  MOVWF  78
0050:  MOVWF  12
0051:  MOVLW  00
0052:  BSF    03.5
0053:  MOVWF  12
....................   while (TRUE) {
....................     output_high(PIN_B0);
0054:  BCF    06.0
0055:  BCF    03.5
0056:  BSF    06.0
....................     delay_ms(500);
0057:  MOVLW  02
0058:  MOVWF  21
0059:  MOVLW  FA
005A:  MOVWF  22
005B:  CALL   004
005C:  DECFSZ 21,F
005D:  GOTO   059
....................     output_low(PIN_B0);
005E:  BSF    03.5
005F:  BCF    06.0
0060:  BCF    03.5
0061:  BCF    06.0
0062:  MOVLW  02
0063:  MOVWF  21
0064:  MOVLW  FA
0065:  MOVWF  22
0066:  CALL   004
0067:  DECFSZ 21,F
0068:  GOTO   064
....................     output_high(PIN_B1);
0069:  BSF    03.5
006A:  BCF    06.1
006B:  BCF    03.5
006C:  BSF    06.1
006D:  MOVLW  02
006E:  MOVWF  21
006F:  MOVLW  FA
0070:  MOVWF  22
0071:  CALL   004
0072:  DECFSZ 21,F
0073:  GOTO   06F
....................     output_low(PIN_B1);
0074:  BSF    03.5
0075:  BCF    06.1
0076:  BCF    03.5
0077:  BCF    06.1
0078:  MOVLW  02
0079:  MOVWF  21
007A:  MOVLW  FA
007B:  MOVWF  22
007C:  CALL   004
007D:  DECFSZ 21,F
007E:  GOTO   07A
....................     output_high(PIN_B2);
007F:  BSF    03.5
0080:  BCF    06.2
0081:  BCF    03.5
0082:  BSF    06.2
0083:  MOVLW  02
0084:  MOVWF  21
0085:  MOVLW  FA
0086:  MOVWF  22
0087:  CALL   004
0088:  DECFSZ 21,F
0089:  GOTO   085
....................     output_low(PIN_B2);
008A:  BSF    03.5
008B:  BCF    06.2
008C:  BCF    03.5
008D:  BCF    06.2
008E:  MOVLW  02
008F:  MOVWF  21
0090:  MOVLW  FA
0091:  MOVWF  22
0092:  CALL   004
0093:  DECFSZ 21,F
0094:  GOTO   090
....................     output_high(PIN_B3);
0095:  BSF    03.5
0096:  BCF    06.3
0097:  BCF    03.5
0098:  BSF    06.3
0099:  MOVLW  02
009A:  MOVWF  21
009B:  MOVLW  FA
009C:  MOVWF  22
009D:  CALL   004
009E:  DECFSZ 21,F
009F:  GOTO   09B
....................     output_low(PIN_B3);
00A0:  BSF    03.5
00A1:  BCF    06.3
00A2:  BCF    03.5
00A3:  BCF    06.3
00A4:  MOVLW  02
00A5:  MOVWF  21
00A6:  MOVLW  FA
00A7:  MOVWF  22
00A8:  CALL   004
00A9:  DECFSZ 21,F
00AA:  GOTO   0A6
00AB:  BSF    03.5
00AC:  GOTO   054
00AD:  SLEEP
Configuration Fuses:
   Word  1: 3FB9   XT NOWDT NOPUT NOPROTECT NOBROWNOUT LVP NOCPD NOWRT NODEBUG
garyzheng
i think it is your configuration's bits problem:)
PostPosted: Tue Jul 27, 2004 8:15 am     Reply with quote
you can not use low voltage program, when you burn your program into your PIC MCU. If you choose the low voltage programming in configuration bits. The RB3 will see as input pin, so you can not control any LEDs by RB3.
rtracy
PostPosted: Tue Jul 27, 2004 8:22 am     Reply with quote
garyzheng:
Thanks a bunch! That was my problem.
I guess that when the manual arrives that I'll have to RTFM.
