monkeytennis
LCD driver problem |
Posted: Wed Jul 21, 2004 8:40 am |
Hi.
I have a circuit built (as in http://ww1.microchip.com/downloads/en/AppNotes/00582b.pdf) and I need it now to do something else. Quite simply it is used to set a day counter and when the countdown is finished, an output pin goes high. I however, have attempted to write a suitable program and have (hopefully) adjusted the LCD.C driver so that it should work, but it doesn't. Can anyone see if there is something obvious that I have done wrong?
(Oh yeah timer1 is driven from an external 32.768KHz watch crystal)
Cheers,
Simon
Code: | // Main C program
#include <16C64A.h>
#include <LCD2.C>
#fuses HS, NOPUT, NOWDT, NOPROTECT, NOBROWNOUT
//Defitions below make it easy to change the settings without playing with the
//program. Change COUNTDOWN to 'days' or 'hours'.
#define COUNTDOWN hours
#define FIRE_PIN1 PIN_C6
#define FIRE_PIN2 PIN_C7
#define UP_PIN PIN_B7
#define SET_PIN PIN_B6
void update_lcddays(void);
int secs=0,hours=0,days=0,dayset=0;
int1 debounce=0;
#int_TIMER1
TIMER1_isr()
set_timer1(0xF000);
secs++;
if (secs==3600)
secs=0;
hours++;
if (hours==24)
hours=0;
days++;
if (COUNTDOWN==dayset)
disable_interrupts(global);
output_high(FIRE_PIN1);
for (secs=0;secs<60;secs++)
output_high(FIRE_PIN2);
int1 set=0,update=1;
int a;
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
port_b_pullups(TRUE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_8);
lcd_init();
enable_interrupts(global);
output_float(UP_PIN);
output_float(SET_PIN);
printf(lcd_putc,"\fChange days setting: %3d",dayset);
do
if (input(UP_PIN)==0)
update=1;
for (a=0;a<10;a++)
if (input(UP_PIN))
update=0;
if (update)
dayset++;
if (dayset==1000)
dayset=0;
if (input(SET_PIN)==0)
set=1;
for (a=0;a<100;a++)
if (input(SET_PIN))
set=0;
}while(set==0);
printf(lcd_putc,"\fSet for %d days",dayset);
while(true);
//// LCDD.C ////
//// Driver for common LCD modules ////
//// lcd_init() Must be called before any other function. ////
//// lcd_putc(c) Will display c on the next position of the LCD. ////
//// The following have special meaning: ////
//// \f Clear display ////
//// \n Go to start of second line ////
//// \b Move back one position ////
//// lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) ////
//// lcd_getc(x,y) Returns character at position x,y on LCD ////
//// (C) Copyright 1996,2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
// As defined in the following structure the pin connection is as follows:
#define enable PIN_A0
#define rs PIN_A2
#define rw PIN_A1
#define D4 PIN_B0
#define D5 PIN_B1
#define D6 PIN_B2
#define D7 PIN_B3
#define TEST PIN_A3
// LCD pins D0-D3 are not used and PIC D3 is not used.
// Un-comment the following define to use port B
// #define use_portb_lcd TRUE
#byte PORTB = 6
#define IN 0xFF
#define OUT 0
struct lcd_pin_map { // This structure is overlayed
BOOLEAN enable; // on to an I/O port to gain
BOOLEAN rs; // access to the LCD pins.
BOOLEAN rw; // The bits are allocated from
BOOLEAN unused; // low order up. ENABLE will
int data : 4; // be pin B0.
} lcd;
#if defined(__PCH__)
#if defined use_portb_lcd
#byte lcd = 0xF81 // This puts the entire structure
#else
#byte lcd = 0xF83 // This puts the entire structure
#else
#byte lcd = 6 // on to port B (at address 6)
#else
#byte lcd = 8 // on to port D (at address 8)
#define set_tris_lcd(x) set_tris_b(x)
#else
#define set_tris_lcd(x) set_tris_d(x)
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD
// to start it up.
// The following are used for setting
// the I/O port direction register.
//struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
//struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
BYTE lcd_read_byte() {
BYTE low,high;
output_high(TEST);
output_float(D4);
output_float(D5);
output_float(D6);
output_float(D7);
output_high(rw);
delay_cycles(1);
output_high(enable);
delay_cycles(1);
set_tris_b(IN);
high = PORTB & 0x0F;
output_low(enable);
delay_cycles(1);
delay_us(1);
low = PORTB & 0x0F;
output_low(enable);
set_tris_b(OUT);
output_low(TEST);
return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
set_tris_b(OUT);
PORTB = n & 0x0F;
delay_cycles(1);
delay_us(2);
output_low(enable);
void lcd_send_byte( BYTE address, BYTE n ) {
output_high(TEST);
output_low(rs);
while (input(D7)) ;
if (address==0)
output_low(rs);
output_high(rs);
delay_cycles(1);
output_low(rw);
delay_cycles(1);
output_low(enable);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
output_low(TEST);
void lcd_init() {
BYTE i;
set_tris_b(OUT);
output_low(rs);
output_low(rw);
output_low(enable);
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
BYTE address;
if(y!=1)
address=lcd_line_two;
address=0;
address+=x-1;
lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
char lcd_getc( BYTE x, BYTE y) {
char value;
lcd_gotoxy(x,y);
while (input(D7)); // wait until busy flag is low
output_high(rs);
value = lcd_read_byte();
output_low(rs);
return(value);
Mark
Posted: Wed Jul 21, 2004 11:12 am |
Here is a version of LCDD.C that I did sometime back allowing the control signals to be on different ports than the data. I changed it per App582. It is untested so try it if you want.
//// LCDD.C ////
//// (C) Copyright 1996,1997 Custom Computer Services ////
// This structure is overlayed onto the data ports so that you may use
// whatever ports you desire
struct lcd_pin_map
BOOLEAN enable; // PinA0
BOOLEAN rw; // PinA1
BOOLEAN rs; // PinA2
BOOLEAN dummy; // PinA3 is not used
int unusedA : 4; // The rest of portA
int data : 4; // lower nibble of portB is used for data lines
int unusedB : 4; // The rest of portB
int unusedC; // portC is not used
int unusedD; // portD is not used
} lcd;
#locate lcd = 0xF80
#else
#locate lcd = 5
struct lcd_tris_map
int control : 3;
} lcdtris;
#locate lcdtris = 0xF92
#else
#locate lcdtris = 0x85
#define set_tris_lcd(x) lcdtris.data = (x); lcdtris.control = 0;
// to start it up.
#define LCD_WRITE 0 // For write mode all pins are out
#define LCD_READ 15 // For read mode data pins are in
BYTE low,high;
set_tris_lcd(LCD_READ);
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
set_tris_lcd(LCD_WRITE);
lcd.data = n;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
lcd.rs = 0;
while ( bit_test(lcd_read_byte(),7) ) ;
lcd.rs = address;
delay_cycles(1);
lcd.rw = 0;
delay_cycles(1);
lcd.enable = 0;
void lcd_init() {
BYTE i;
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
BYTE address;
if(y!=1)
address=0;
address+=x-1;
switch (c) {
delay_ms(2);
char value;
lcd_gotoxy(x,y);
lcd.rs=1;
lcd.rs=0;
return(value);
monkeytennis
Posted: Thu Jul 22, 2004 3:13 am |
Cheers, I'll give that a bash!
Simon |
monkeytennis
Posted: Thu Jul 22, 2004 7:09 am |
Cheers for that, it worked spot-on first time. Now I've just gotta work out why the rest of it doesn't work.
Simon |
