djipe
Need Help on 18F1320 |
Posted: Tue Jul 20, 2004 9:12 am |
Hello, I'm newbeez with 18F1320 and do not succed to make work this one
I think my problem is to configure fuses.
I did a a program to send "123456" through the RS232.
It did it when I put on power but some time it did it again
Do anybody could help me please ?
Do you have an exemple of project to give ?
Djipe. |
Posted: Tue Jul 20, 2004 6:07 pm |
Can u elaborate your problem... it seems you don't experience problem as stated in your post... |
djipe
Posted: Wed Jul 21, 2004 3:11 am |
My problem is, I don't know how to configure fuses with CCS when create a wisard project.
So, I try to configure it but all my program reset alone
I think, the best will be any body whose work with 18F1320 give me an exemple of program configured for this pic.
With this one, I can analyse fuses and use it for future. |
ttelmah Guest
Re: Need Help on 18F1320 |
Posted: Wed Jul 21, 2004 3:57 am |
djipe wrote: | Hello, I'm newbeez with 18F1320 and do not succed to make work this one
Djipe. |
I'm afraid you are going to have to do some work yourself.
Read the chips data sheet. This gives the fuses. Then you need to work out which ones _you_ want set for your project (this changes with the hardware you are using, so there is no 'generic' answer, except when people are working with known hardware combinations, like some of the 'prototyping' boards). Then the 'symbolic' names are listed in the header file for the chip. If you cannot work out how these relate to the real fuses, post back, and somebody can then help.
The most likely reason for a 'repeated' printout, is that the hardware watchdog is enabled, and the code is running 'off the end', or sitting in an infinite loop. The watchdog, then triggers, restarting the processor. This is disabled with the 'NOWDT' fuse setting.
So a bit of code like:
main() {
printf("test\n");
delay_ms(5);
With the watchdog timer enabled, will actually print:
test
test
test
etc., as the code runs off the end of the main loop, hits the hidden 'sleep' instruction that CCS place there, goes to sleep, and then the watchdog triggers.
Posted: Wed Jul 21, 2004 11:49 am |
ttelmah wrote: | I'm afraid you are going to have to do some work yourself.
Read the chips data sheet. This gives the fuses. |
I did it many time but ....
I do not success to use it.
I begin to borred. May be thi PIC will have to learn to fly.
I've implemented a voltage regulator, setup my capacitor the nearest of the PIC VDD.
I did this modification, because I've seen that when I shut down power, the pic look's working correctly
And now, with this modification, the result is worst
For two weeks, I've been trying and trying .... and still not have any result...
If any body has work in the past with the 18F1320, Please, could you send me your Fuses to do button-LED and a PRINTF.
Thanks |
chingB
Posted: Wed Jul 21, 2004 6:20 pm |
Try this code below:
#include <18F1320.h> // MCU specific library
#device *=16
#fuses HS,NOLVP,NOWDT,NOPROTECT,MCLR
#use delay (clock=20000000) // 20MHz clock
#define LED PIN_A2
void led_func()
output_high(LED);
output_low(LED);
main()
delay_ms(2000);
setup_adc_ports(NO_ANALOGS);
led_func();
The code below uses the internal 8MHz oscillator
#device *=16
#fuses INTRC_IO,NOLVP,NOWDT,NOPROTECT,MCLR
#use delay (clock=8000000) // 8MHz clock
#byte OSCCON = 0xFD3
#byte SPBRGH = 0xFB0
#byte SPBRG = 0xFAF
#byte TXREG = 0xFAD
#byte RCSTA = 0xFAB
#byte RCREG = 0xFAE
#bit BRG16 = 0xFAA.3
#bit BRGH = 0xFAC.2
#bit SYNC = 0xFAC.4
#bit SPEN = 0xFAB.7
#bit TX9 = 0xFAC.6
#bit TXEN = 0xFAC.5
#bit TXIF = 0xF9E.4
#bit TXIE = 0xF9D.4
#bit RX9 = 0xFAB.6
#bit CREN = 0xFAB.4
#bit RCIF = 0xF9E.5
#bit FERR = 0xFAB.2
#bit OERR = 0xFAB.1
#define LED PIN_A2
char rcvChar = 0;
char txvChar = 0;
#int_rda
void rda_isr()
rcvChar = RCREG;
if (OERR){
CREN = 0;
#asm nop #endasm
CREN = 1;
void led_func()
output_high(LED);
output_low(LED);
main()
delay_ms(2000);
setup_oscillator(OSC_8MHZ|OSC_INTRC);
SPBRGH = 0;
SPBRG = 16;
BRG16 = 1;
BRGH = 1;
SYNC = 0;
SPEN = 1;
TX9 = 0;
TXEN = 1;
TXIF = 0;
RX9 = 0;
CREN = 1;
RCIF = 0;
enable_interrupts(int_rda);
//enable_interrupts(int_tbe);
enable_interrupts(global);
led_func();
TXREG = 'A';
TXREG = ' ';
TXREG = rcvChar;
I hope this helps.... I agree with ttelmah that you need to read the data sheets ---> u get a lot of information there!!! one thing try search this forum coz there are a lot of sample snippet that uses PIC18F1320... razz: |
djipe
Posted: Thu Jul 22, 2004 1:15 pm |
chingB wrote: | I hope this helps.... I agree with ttelmah that you need to read the data sheets ---> u get a lot of information there!!! one thing try search this forum coz there are a lot of sample snippet that uses PIC18F1320... razz: |
Thank you for your code, it's very interesting.
In my schematic I've found a big big big mistake
I use a christal and I set up my capacitors to the +5V
It's the reason why I had so much reset
Now, I now I'll never do it again
One more time, thank you.
Djipe. |
