I have something curious happening in my program and was wondering if anyone can explain it.
In line 17 below " if (!aff_power) init_done=0;" gives me a warning that it will always be false but the line works as it should.
I was wondering if anyone knows why i am getting the warning?
#define AFF_Power PIN_A1 //pin 18 - pin RA1
int init_done;
<snip>
restart_wdt();
// read the switch state to get start signal status
start_signal = input(pin_A0); // get start signal input
if (input(MP_BOL)==unblocked){
Jam_flag=0;
jam_timer=0;
if (!aff_power)
init_done=0;
// Is the MP BOL blocked?
if ((input(MP_BOL)== blocked) && (idle == 0))
if (jam_flag==0) // is this the first time seen?
jam_stop=0;
jam_flag = 1; // if so, start timer and set flag
Jam_Timer = JAM_TIME;
rwyoung
Posted: Mon Jul 19, 2004 8:53 am
I'm supprised it works at all.
The PIN_Ax assignments (as I understand them) are not the port addresses themselves. You are doing the same basic operation as
if (!22) init_done=0;
(substitue the value of PIN_A0 from your header file for 22).
You should either use the input_pin() function or use the #byte and #bit feature to map your pin to a variable.
FYI, if you use the input_pin() function then #use standard_io() will work as well as #use fast_io() and #use fixed_io()
However if you use the #byte and #bit you must set the pin direction by programming the appropriate TRIS register. _________________ Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
