use 18F8520 external memory, microprocessor mode, problem!
micman
PostPosted: Mon Mar 17, 2003 2:44 am     Reply with quote
I use a 16f8520 in micorprocessor mode with external memory, I want to know if pch support the this modality and if there are of the examples on to implement it in ccs.
___________________________
Original Post ID: 12760
Kevin Howell
Re: use 18F8520 external memory, microprocessor mode, proble
PostPosted: Sat Apr 05, 2003 1:09 am     Reply with quote
I would love the same information....
Do you have schematics on how to actually wire a JEDEC flash memory up to it?
Kevin
:=Hi,
:=I use a 16f8520 in micorprocessor mode with external memory, I want to know if pch support the this modality and if there are of the examples on to implement it in ccs.
:=Thanks
Original Post ID: 13434
micman
PostPosted: Sat Apr 05, 2003 2:03 am     Reply with quote
I have still not had answer. to actually wire a JEDEC flash memory up to it, you go in the data-sheet
:=I would love the same information....
:=Do you have schematics on how to actually wire a JEDEC flash memory up to it?
:=Kevin
:=:=Hi,
:=:=I use a 16f8520 in micorprocessor mode with external memory, I want to know if pch support the this modality and if there are of the examples on to implement it in ccs.
:=:=Thanks
Original Post ID: 13438
