tbsnake2 Guest
Trouble with 16f88 UART |
Posted: Wed Jul 14, 2004 7:29 am |
Hello. I am trying to use the hardware UART on the pic16F88. The issue seems to be that kbhit continues to find something in the buffer. Pressing a letter "k" returns the following:
"Letter kLetter LLetter e" then the pic freezes here.
#include <16F88.h>
#use delay(clock=38400)
#use rs232(baud=300,parity=N,xmit=PIN_B5,rcv=PIN_B2,bits=8)
#define IRRXPWR PIN_A0
#byte PIR1 = 0x0c
#byte PORTB = 0x06
#byte PORTA = 0x05
int i,j;
set_tris_A (0x21);
set_tris_B (0x47);
setup_adc(ADC_OFF);
port_b_pullups(FALSE);
setup_spi(FALSE);
setup_uart(TRUE);
while(1){
for(i=0; i<100; i++){
if(kbhit()){
j = getc();
delay_ms(300);
printf("Letter %C",j);
delay_ms(300);
Re: Trouble with 16f88 UART |
Posted: Wed Jul 14, 2004 7:50 am |
tbsnake2 wrote: | Hello. I am trying to use the hardware UART on the pic16F88. The issue seems to be that kbhit continues to find something in the buffer. Pressing a letter "k" returns the following:
#include <16F88.h>
#byte PIR1 = 0x0c
#byte PORTB = 0x06
#byte PORTA = 0x05
int i,j;
set_tris_A (0x21);
set_tris_B (0x47);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_uart(TRUE);
while(1){
if(kbhit()){
j = getc();
delay_ms(300);
delay_ms(300);
I think the terminal program you are using, is echoing the characters back. You are seeing the first two characters of the word 'Letter'...
With the delays in your loop, the receive hardware buffer in the UART, then overflows, and since you have not specified 'ERRORS' (which would clear this), the UART, is then hung.
Find out why the characters are being echoed back, and if you are going to delay in the receive code, consider using an interrupt driven serial buffer (look in the examples for how to do this).
