esinger
can't get PIC16c745 USB to enumerate |
Posted: Tue Jul 13, 2004 8:49 am |
I am trying to create a standard USB 104-key PC keyboard emulator on a PIC 16c745 using the CCS C compiler version 3.0.0.13 under MPLAB5. I started with the CCS USB example code, then modified it to be a standard keyboard device.
I can get the device to enumerate when I use the example descriptor. However, my modified one won't enumerate properly. I have checked it against numerous references, and it appears to be correct.
I'm copying my descriptor below. I would be grateful if anyone could shed some light on this issue.
Thanks,
Eric
#DEFINE USB_NUM_CONFIGURATIONS 1
#DEFINE USB_NUM_INTERFACES 1
#DEFINE USB_NUM_ENDPOINTS 1
#DEFINE USB_NUM_CLASSES 1 // hid
BYTE CONST USB_CONFIG_DESCRIPTORS[USB_NUM_CONFIGURATIONS] = {0};
BYTE CONST USB_INTERFACE_DESCRIPTORS[USB_NUM_INTERFACES] = {9};
BYTE CONST USB_CLASS_DESCRIPTORS[USB_NUM_CLASSES] = {18};
BYTE CONST USB_ENDPOINT_DESCRIPTORS[USB_NUM_ENDPOINTS] = {27};
#DEFINE USB_TOTAL_CONFIG_LEN 34 // config + interface + class + endpoint
#DEFINE USB_HID_DESC_LEN 63
BYTE CONST USB_DEVICE_DESC[] = {
USB_DEVICE_DESC_LEN, // the length of this report ==1
0x01, // the constant DEVICE (DEVICE 0x01) ==2
0x10, 0x01, // usb version in bcd (pic167xx is 1.1) ==3,4
0x00, // class code ==5
0x00, // subclass code ==6
0x00, // protocol code ==7
USB_MAX_EP0_PACKET_LENGTH, // max packet size for endpoint 0. (SLOW SPEED SPECIFIES 8) ==8
0xD8, 0x04, // vendor id (0x04D8 is Microchip, or is it 0x0461 ??)
0x01, 0x00, // product id ==11,12 // don't use ffff says usb-by-example guy. oops
0x00, 0x01, // device release number ==13,14
0x00, // index of string description of manufacturer. therefore we point to string_1 array (see below) ==15
0x00, // index of string descriptor of the product ==16
0x00, // index of string descriptor of serial number ==17
USB_NUM_CONFIGURATIONS // number of possible configurations ==18
BYTE CONST USB_CONFIG_DESC[USB_TOTAL_CONFIG_LEN] = {
// config_descriptor for config index 1
USB_CONFIG_DESC_LEN, // length of descriptor size ==1
USB_CONFIG_DESC_KEY, // constant CONFIGURATION (CONFIGURATION 0x02) ==2
USB_TOTAL_CONFIG_LEN, 0, // size of all data returned for this config ==3,4
USB_NUM_INTERFACES, // number of interfaces this device supports ==5
0x01, // identifier for this configuration. (IF we had more than one configurations) ==6
0x00, // index of string descriptor for this configuration ==7
0x80, // bit 6=1 if self powered, bit 5=1 if supports remote wakeup (we don't), bits 0-4 unused and bit7=1 ==8
0x32, // maximum bus power required (maximum milliamperes/2) (0x32 = 100mA)
// interface descriptor 1
USB_INTERFACE_DESC_LEN, // length of descriptor =10
USB_INTERFACE_DESC_KEY, // constant INTERFACE (INTERFACE 0x04) =11
0x00, // number defining this interface (IF we had more than one interface) ==12
0x00, // alternate setting ==13
USB_NUM_ENDPOINTS, // number of endpoins, except 0 (pic167xx has 3, but we dont have to use all). ==14
0x03, // class code, 03 = HID ==15
0x01, // subclass code // boot ==16
0x01, // protocol code // 1=kbd ==17
0x00, // index of string descriptor for interface ==18
// class descriptor 1 (HID)
USB_CLASS_DESC_LEN, // length of descriptor ==19
USB_CLASS_DESC_KEY, // dscriptor type (0x21 == HID) ==20
0x00, 0x01, // hid class release number (1.0) ==21,22
0x00, // localized country code (0 = none) ==23
0x01, // number of hid class descrptors that follow (1) ==24
0x22, // report descriptor type (0x22 == HID) ==25
USB_HID_DESC_LEN, 0x00, // length of report descriptor ==26,27
// endpoint descriptor
USB_ENDPOINT_DESC_LEN, // length of descriptor ==28
USB_ENDPOINT_DESC_KEY, // constant ENDPOINT (ENDPOINT 0x05) ==29
0x81, // endpoint number and direction (0x81 = EP1 IN) ==30
0x03, // transfer type supported (0x03 is interrupt) ==31
0x08, 0x00, // maximum packet size supported ==32,33
0x0A // polling interval, in ms. (cant be smaller than 10) ==34
BYTE CONST USB_HID_DESC[] = {
// len = 63
0x05, 0x01 // usage page (generic desktop)
0x09, 0x06 // usage (keyboard)
0xA1, 0x01 // collection (application)
0x05, 0x07 // usage page (key codes)
0x19, 0xE0 // usage minimum (224)
0x29, 0xE7 // usage maximum (231)
0x15, 0x00 // logical minimum (0)
0x25, 0x01 // logical maximum (1)
0x75, 0x01 // report size (1)
0x95, 0x08 // report count (8)
0x81, 0x02 // input (data, variable, absolute)
0x95, 0x01 // report count (1)
0x75, 0x08 // report size (8)
0x81, 0x01 // input (constant)
0x95, 0x05 // report count (5)
0x05, 0x08 // usage page (page# for LEDs)
0x19, 0x01 // usage minimum (1)
0x29, 0x05 // usage maxmimum (5)
0x91, 0x02 // output (data, variable, absolute)
0x75, 0x03 // report size (3)
0x91, 0x01 // output (constant)
0x95, 0x06 // report count (6)
0x25, 0x65 // logical maximum (101)
0x19, 0x00 // usage minimum (0)
0x29, 0x65 // usage maximum (101)
0x81, 0x00 // input (data, array)
0xC0 // end collection
#DEFINE USB_STRING_0_LEN 4
BYTE CONST USB_STRING_0[USB_STRING_0_LEN] = {
// string index 0 is special
USB_STRING_0_LEN, // length of string index
0x03, // descriptor type 0x03 (STRING)
0x09, 0x04 // Microsoft Defined for US-English
etc.... |
guest Guest
Posted: Tue Aug 10, 2004 6:01 am |
Hi Eric,
I've got the same problem, I used the mouse-descriptor, and it worked, then I used a keyboard desc wich worked with HI-TECH C V7.87 PL2, but it does not work with CCS.
If you manage it, please tell me: gaul1@compuserve.de
I've to try further.
good luck !
gaul1 |
gaul1 Guest
I got PIC16c745 USB to enumerate |
Posted: Thu Aug 12, 2004 8:17 am |
Hi Eric,
with my hardware, this works (picdem USB+16c765) javascript:emoticon(' ')
Laughing
good luck !
gaul1
//usb descriptor reports
#DEFINE USB_NUM_CLASSES 1 //hid
//you cant use pointers when storing constants to program memory.
BYTE CONST USB_CONFIG_DESCRIPTORS[USB_NUM_CONFIGURATIONS]={0};//0
BYTE CONST USB_INTERFACE_DESCRIPTORS[USB_NUM_INTERFACES]={9};//9
BYTE CONST USB_CLASS_DESCRIPTORS[USB_NUM_CLASSES]={18};//18
BYTE CONST USB_ENDPOINT_DESCRIPTORS[USB_NUM_ENDPOINTS]={27};//27
#DEFINE USB_TOTAL_CONFIG_LEN 34 //config+interface+class+endpoint
//starts of with device configuration. only one possible
0x12, // USB_DEVICE_DESC_LEN, //the length of this report ==1 // len=18=0x12
//dev,0, 1, 0, 0, 0, 8, 0xD8, 4, 0x0C, 0, 0x41, 4, 1, 2, 0, 1 // von usb_ch9.c
0x01, //the constant DEVICE (DEVICE 0x01) ==2
0x00,0x01, //usb version in bcd (pic167xx is 1.1) ==3,4
0x00, //class code ==5
0x00, //subclass code ==6
0x00, //protocol code ==7
8, //USB_MAX_EP0_PACKET_LENGTH, //max packet size for endpoint 0. (SLOW SPEED SPECIFIES 8) ==8
0xD8,0x04, //vendor id (0x04D8 is Microchip, or is it 0x0461 ??)
0x0C,0x01, //product id ==11,12 //don't use ffff says usb-by-example guy. oops!
0x41, 5, //device release number ==13,14!
0x01, //index of string description of manufacturer. therefore we point to string_1 array (see below) ==15
0x02, //index of string descriptor of the product ==16
0x00, //index of string descriptor of serial number ==17
1 //USB_NUM_CONFIGURATIONS //number of possible configurations ==18
//IN ORDER TO COMPLY WITH WINDOWS HOSTS, THE ORDER OF THIS ARRAY MUST BE:
// config(s)
// interface(s)
// class(es)
// endpoint(s)
//config_descriptor for config index 1
9, //USB_CONFIG_DESC_LEN, //length of descriptor size ==1
2, //USB_CONFIG_DESC_KEY, //constant CONFIGURATION (CONFIGURATION 0x02) ==2
34,0, //USB_TOTAL_CONFIG_LEN,0, //size of all data returned for this config ==3,4
1, //USB_NUM_INTERFACES, //number of interfaces this device supports ==5
0x01, //identifier for this configuration. (IF we had more than one configurations) ==6
0x00, //index of string descriptor for this configuration ==7
0xa0, // von usb_ch9[a0] //0xC0, //bit 6=1 if self powered, bit 5=1 if supports remote wakeup (we don't), bits 0-4 unused and bit7=1 ==8
0x32, //maximum bus power required (maximum milliamperes/2) (0x32 = 100mA)
//interface descriptor 1
9, //USB_INTERFACE_DESC_LEN, //length of descriptor =10
4, //USB_INTERFACE_DESC_KEY, //constant INTERFACE (INTERFACE 0x04) =11
0x00, //number defining this interface (IF we had more than one interface) ==12
0x00, //alternate setting ==13
1, //USB_NUM_ENDPOINTS, //number of endpoins, except 0 (pic167xx has 3, but we dont have to use all). ==14
0x03, //class code, 03 = HID ==15
0x01, //subclass code //boot ==16
1, //0x02, //protocol code ==17
0x00, //index of string descriptor for interface ==18
//class descriptor 1 (HID)
9, //USB_CLASS_DESC_LEN, //length of descriptor ==19
0x21, //USB_CLASS_DESC_KEY, //dscriptor type (0x21 == HID) ==20
0x00,0x01, //hid class release number (1.0) (try 1.10) ==21,22
0x00, //localized country code (0 = none) ==23
0x01, //number of hid class descrptors that follow (1) ==24
0x22, //report descriptor type (0x22 == HID) ==25
USB_HID_DESC_LEN, 0x00, //length of report descriptor (LowByte,HighByte) ==26,27
//endpoint descriptor
7, //USB_ENDPOINT_DESC_LEN, //length of descriptor ==28
5, //USB_ENDPOINT_DESC_KEY, //constant ENDPOINT (ENDPOINT 0x05) ==29
0x81, //endpoint number and direction (0x81 = EP1 IN) ==30
0x03, //transfer type supported (0x03 is interrupt) ==31
0x08,0x00, //maximum packet size supported ==32,33
0x0a, //polling interval, in ms. (cant be smaller than 10 for slow speed devices) ==34
/// HID Report. Tells HID driver how to handle and deal with
/// received data. HID Reports can be extremely complex,
/// see HID specifcation for help on writing your own.
/// This examples configures HID driver to take received data
/// as keyboard
//mine
BYTE CONST USB_HID_DESC[] = { //len=63
0x05, 0x01, // usage page (generic desktop)
0x09, 0x06, // usage (keyboard)
0xA1, 0x01, // collection (application)
0x05, 0x07, // usage page (key codes)
0x19, 0xE0, // usage minimum (224)
0x29, 0xE7, // usage maximum (231)
0x15, 0x00, // logical minimum (0)
0x25, 0x01, // logical maximum (1)
0x75, 0x01, // report size (1)
0x95, 0x08, // report count (8)
0x81, 0x02, // input (data, variable, absolute)
0x95, 0x01, // report count (1)
0x75, 0x08, // report size (8)
0x81, 0x01, // input (constant)
0x95, 0x05, // report count (5)
0x05, 0x08, // usage page (page# for LEDs)
0x19, 0x01, // usage minimum (1)
0x29, 0x05, // usage maxmimum (5)
0x91, 0x02, // output (data, variable, absolute)
0x75, 0x03, // report size (3)
0x91, 0x01, // output (constant)
0x95, 0x06, // report count (6)
0x25, 0x65, // logical maximum (101)
0x19, 0x00, // usage minimum (0)
0x29, 0x65, // usage maximum (101)
0x81, 0x00, // input (data, array)
/// start string descriptors ![Laughing](images/smiles/icon_lol.gif) |
