Problems with LCD driver by PIC 16F628.
Boon
PostPosted: Sat Jul 10, 2004 1:29 am     Reply with quote
I have problems with LCD driver. I use PIC 16F628. input data from scan barcode . How can i do?
jds-pic
Re: Problems with LCD driver by PIC 16F628.
PostPosted: Sat Jul 10, 2004 3:50 pm     Reply with quote
load your code onto PIC. connect barcode scanner to PIC. connect LCD to PIC. pass barcode under scanner. see results on LCD.
jds-pic
Boon
Thanks for the suggestion
PostPosted: Sun Jul 11, 2004 7:28 pm     Reply with quote
Thanks for the suggestion. However, I want to also example by PIC C . Help me please. Crying or Very sad
jds-pic
Re: Thanks for the suggestion
PostPosted: Sun Jul 11, 2004 10:47 pm     Reply with quote
you are not going to get any help at this rate. you've provided no description of your problem, no description of either your HW or SW architecture, no description of the errors that are occuring, no description of the troubleshooting steps that you've tried, no code snippets, etc etc etc ad nauseum -- and yet you want "example PIC C code". for what? an LCD driver? a barcode scanner driver ? basic PIC16F628 infrastructure?
summary:
we can't do your school project for you unless we see the assignment, and understand what resources are available.
jds-pic
Boon
PostPosted: Mon Jul 12, 2004 7:27 pm     Reply with quote
normally i use 16F877. i will change to 16F628 . it's error when compile. i want to known . what wrong? this my code
#include<16f877.h>
#fuses HS,NOPROTECT,NOWDT,NOLVP
#include <lcd.c>
int i,value,min,max,j=0,k=0;
char msg1[5]="HELP",msg2[7]="NORMAL",msg3[5]="STOP",msg4[10]="NO_LOAD",msg5[]="OVER_LOAD";
void main(void) // Begin Program
printf("Sampling:");
setup_port_a( ALL_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
do {
min=255;
max=0;
for(i=0;i<=30;++i)
delay_ms(10);
value = Read_ADC();
if(value<min)
min=value;
if(value>max)
max=value;
if (min<0x35) //**********NO_LOAD******************************************
j=j+1 ;
lcd_init() ;
lcd_getc(7,1) ;
printf(lcd_putc,msg1); // Output LCD HELP
lcd_getc(5,2) ;
printf(lcd_putc,msg4); // Output LCD NO_LOAD
printf(lcd_putc,"\f"); // Clear LCD
if (j >= 10 )
output_b(0x02);
lcd_getc(7,1) ;
printf(lcd_putc,msg3); // Output LCD STOP
lcd_getc(5,2) ;
if (min>0x9a) //***********OVER_LOAD****************************************
j=j+1 ;
lcd_init() ;
lcd_getc(7,1) ;
lcd_getc(4,2) ;
printf(lcd_putc,msg5); // Output LCD OVER_LOAD
if (j >= 10 )
output_b(0x02);
lcd_getc(7,1) ;
lcd_getc(4,2) ;
if ((min>0x35)&&(min<0x9a)) //***** Reset j value****
k=k+1;
lcd_init() ;
lcd_getc(k,1) ;
printf(lcd_putc,msg2); // Output LCD NOMAL
lcd_getc(k,2) ;
j=0;
if (k>16)
k=0;
printf("\n\rMin: %2X Max: %2X j: %2d k: %2d\r\n ",min,max,j,k);
}while (TRUE);
} // End Program ********************************************************
jds-pic
PostPosted: Mon Jul 12, 2004 8:03 pm     Reply with quote
what's the error message?
jds-pic
ps:
please use the "Code" button when inserting code -- it makes it much more readable.
Boon
PostPosted: Tue Jul 13, 2004 7:28 pm     Reply with quote
Error message is
1: Use parameter value is out of range Not a number :PIN_C6
2: Undefined identifier
One error message i understand i change port_c is port_b . When compile it's show lcd.c page and error second message. I don't understand.What happen?
PostPosted: Tue Jul 13, 2004 9:12 pm     Reply with quote
The code compiles fine for the 16F877 but will not compile for the 16F628 because you are trying to use analog channels it does not have.....
This chip will not work for what you want....
Boon
PostPosted: Wed Jul 14, 2004 3:17 am     Reply with quote
Thank you .Yes,i know. this code for example . if i don't use analog channels .I want to know if i will use 16F628 for drive LCD. i will use LCD for show data. how i can do? i need help! please.....
PostPosted: Wed Jul 14, 2004 4:04 am     Reply with quote
Look at the data sheet for the 16F628 - there are differences when compared to the 16F877.
You should be showing us the code you have when trying to compile for the 16F628. Get rid of the analog stuff, get rid of the #use rs232 line because the 16F628 uses pins RB2 for transmit and RB1 for receive, and you need to use port b for the lcd.
Boon
PostPosted: Thu Jul 15, 2004 7:17 pm     Reply with quote
I'm thank you Jds-pic, Dyeatman and Guest very much for the suggestion. Now i can use pic 16f628 with lcd . thank you very much Laughing Laughing Laughing
