mvaraujo
Printf output problem? |
Posted: Mon Jul 05, 2004 7:56 am |
Hi all,
I have something like this on my code:
Code: | printf(disp_store,"%03lu.%1uV %02u.%1uHz",v_rms,v_rms_dec,freq,freq_dec); |
It seams that sometimes it didn't output 16 characters but one less. Did you guys experience any problems like that on printf command?
Thanks!
Marcus |
Posted: Mon Jul 05, 2004 11:47 am |
Quote: | It seems that sometimes it didn't output 16 characters but one less |
I made a test file and compiled it for the 16F877 with PCM vs. 3.188.
It works. I changed the printf statement to remove the output
to "disp_store", and instead I sent it to my terminal window.
I also added a 2nd line, which shows the character count.
Here are the results displayed in the terminal window:
Code: | 012.3V 04.5Hz
1234567890123456 |
Here is the test program:
Code: | #include <16F877.h>
#use delay(clock = 4000000)
main()
int16 v_rms;
int8 v_rms_dec;
int8 freq;
int8 freq_dec;
v_rms = 12;
v_rms_dec = 3;
freq = 4;
freq_dec = 5;
printf("%03lu.%1uV %02u.%1uHz",v_rms,v_rms_dec,freq,freq_dec);
printf("\n\r1234567890123456\n\r");
If this reply does not fix your problem then you should post
your own test program that demonstrates the problem, and
also give the PIC and the version of your compiler. |
mvaraujo
Posted: Mon Jul 05, 2004 12:37 pm |
PCM programmer,
In fact I use this command and it works on the application. The point is that sometimes it sends other character less to the output. I still didn't find any correlation to interrupt services.
My question intends to know if any buggy behaviour in printf() is know by people!
Thanks!
Marcus |
Posted: Mon Jul 05, 2004 7:57 pm |
the last one char will not be sent out if without the ... while(1); ... because CCS send PIC into sleep before the last one get out.
that's what happened to me years ago. |
