Newbie Beset by 16F84A Resets -- HELP!
Rollo
PostPosted: Sat Mar 15, 2003 10:55 am     Reply with quote
Greetings All!
Got a CCS compiler and Warp-13A kit a couple of days ago. Migrating from BS2. CCS nicely integrates into MPLAB. Was able to get the obligatory "Hello_LED" program going.
But, when I try any longer program ( more than 1 sec ), the WDT starts up and resets me about every second. I've spent two days reading 16F84A data sheets, digging around the PICLIST, this list, purchasing Predko's book, looking at CCS and PIC code examples. Everything compiles and verifies fine, but something's wrong, but I can't see what it is?
It keeps re-setting as if the WDT was selected on, when the fuses were defined as NOWDT.
I tried a variety of codes. The latest is to light and turn off each segment of a 7-seg LED in a loop. It only lights 3 segments, and then restarts. ( New 9V battery thru
Here's what I've tried, so far to try to get rid of "WDT".
1- Made sure to use a 0.1uF cap to Ground on the PIC Vdd pin.
2- Made sure to have a 10K resistor on Vss pin.
3- Using 7805A 5V regulator with caps - for noise reduction.
4- I've made sure to have the #FUSE say HS, NOWDT
5- I purchased a different PIC and FOX F1100E Osc ( no change).
6- I exchanged the 7-seg-LED for another ( no change ).
7- I exchanged the 7805A for another ( no change ).
8- Ran it in RC mode, with resistor and cap. ( no change ).
9- Resistors on all unused pins and set to output. ( n c ).
10- Set Tris on Ports A and B to zero or not. ( n c ).
11- Tried 2 new 9V batteries -- no change.
Been two days. Looking longingly at all the interesting code. I know I'm doing something wrong, but what?! I can do the kludge of doing a reset WDT, but that's too bad, since I wrote NOWDT, so should not have to do that.
I'm really hoping one of you already have an idea what I might be doing wrong, or what I should try next.
Here is my simple code:
#INCLUDE <16F84A.h>
#USE delay (clock = 10000000)
#FUSES HS,NOWDT,PUT
set_tris_A(0);
set_tris_B(0);
void poz(){
delay_ms(300);
//#asm
//clrwdt
//#endasm
int8 x=0;
do{
output_low(PIN_B0);
poz();
output_high(PIN_B0);
poz();
output_low(PIN_B1);
poz();
output_high(PIN_B1);
poz();
output_low(PIN_B2);
poz();
output_high(PIN_B2);
poz();
output_low(PIN_B3);
poz();
output_high(PIN_B3);
poz();
output_low(PIN_B4);
poz();
output_high(PIN_B4);
poz();
output_low(PIN_B5);
poz();
output_high(PIN_B5);
poz();
output_low(PIN_B6);
poz();
output_high(PIN_B6);
poz();
output_low(PIN_B7);
poz();
output_high(PIN_B7);
poz();
} while(true);
Rol - PIC Newbie
___________________________
Original Post ID: 12716
sar
Re: Newbie Beset by 16F84A Resets -- HELP!
PostPosted: Sat Mar 15, 2003 11:39 am     Reply with quote
Rollo
I compiled your code and made delay_ms (2000) and it worked perfect. Did you set your config bits on the warp 13 to no wdt? I used a epic programmer as I don't have the warp 13.
Original Post ID: 12719
Rollo
PostPosted: Sat Mar 15, 2003 12:42 pm     Reply with quote
YES!... That was it. Thanks so much.
Since I was using MPLAB, and since MPLAB treats a Warp13A as a PICSTART PLUS, and finally since CSS C integrates so well into MPLAB, I had not tried to study or use the Warp13A software, in the first 48hrs of newbie "trial and error".
I didn't realize that adding the CCS #FUSES NOWDT directive wasn't enough to ensure that the WDT would be off when I wanted it off. You've saved me TONS of further aggravation. Thanks!
I wonder if I could achieve the same result somehow from within MPLAB, instead of having to hop over to my Warp13A software each time?
In any case, you pointed me in the right direction, and now I can make this work, and "boldly go" on to larger programs.
Thanks Again for taking the time,
Rol
:=Rollo
:=I compiled your code and made delay_ms (2000) and it worked perfect. Did you set your config bits on the warp 13 to no wdt? I used a epic programmer as I don't have the warp 13.
Original Post ID: 12721
Rollo
Addendum - found Config Bits menu in MPLAB
PostPosted: Sat Mar 15, 2003 1:07 pm     Reply with quote
Just to say that I found the config bits submenu in MPLAB, so I can do this from there. Newbie Fog left me confused about the #FUSES directive -- looks like these bits also have to be set manually as well.
Thanks,
Rol
Original Post ID: 12722
