moritz
12f675 adc problem |
Posted: Fri Jul 02, 2004 4:35 pm |
Hi there, I've taken some code from the forum to get the ADC on the 12f675 to work, with no success. The following program seems to stall at the line:
Value=read_adc();
If I comment it out (//) it works fine. Any suggestions are greatly appreciated. Thanks, Moritz.
#include <12F675.h>
#device ADC=10
// Connections:
// PIN 1 to VCC
// PIN 2 to 220 Ohms resistor + LED
// PIN 3 to 220 Ohms resistor + LED
// PIN 4 10K to VCC
// PIN 5 n.c.
// PIN 6 n.c.
// PIN 7 to 3 pins Potentiomenter 10k Ohms ( PIN1 to VCC, PIN 2 to PIC
// PIN7, PIN 3 to GND)
// PIN 8 to GND
#fuses INTRC_IO,NOWDT,NOBROWNOUT,NOPROTECT,PUT,MCLR
//#fuses MCLR,PUT,NOPUT,RC,EC,RC_IO,INTRC_IO,BROWNOUT,NOBROWNOUT
int16 Value=300;
set_tris_a(0b00000111);//RA0, RA1, RA2 as Inputs
//RA3, RA4, RA5 as Outputs
setup_adc_ports( RA0_ANALOG );
setup_adc(ADC_CLOCK_INTERNAL );
set_adc_channel(0);
delay_ms(150); // Allow the channel to be aquired
output_bit(pin_a5,1);
delay_ms (250);
output_bit(pin_a5,0);
delay_ms(10);
Value=read_adc();
delay_ms(10);
if (Value > 512)//If more than 50% Flash fast
output_high(pin_a4);
delay_ms (250);
output_low(pin_a4);
delay_ms(250);
else //if (Value < 513) Flash slow
delay_ms (1500);
output_low(pin_a4);
delay_ms(1500);
| [/code] |
Posted: Fri Jul 02, 2004 5:02 pm |
What's your version of the compiler ? |
moritz
compiler version 3.1.0.23 |
Posted: Fri Jul 02, 2004 6:16 pm |
Hi, I've got compiler version 3.1.0.23
Cheers, Moritz. |
Posted: Fri Jul 02, 2004 6:44 pm |
Could you clarify that a bit ? That number is not in
the usual CCS format. See this page to see how
they write their version numbers:
http://www.ccsinfo.com/versions.shtml |
moritz
Where can I find the version number? |
Posted: Sat Jul 03, 2004 4:06 am |
That number was the version number of the exe file. I just cannot find the real version number, where do they write this?
Thanks for your patience with me...
Moritz. |
moritz
found it: 3.091 |
Posted: Sat Jul 03, 2004 4:50 am |
It's version 3.091 |
Posted: Sat Jul 03, 2004 12:19 pm |
I installed vs. 3.091 and compiled your program. I looked at the
start-up code inserted by the compiler, and it's incorrect.
Also, for that version, the setup_comparator() function creates
incorrect code.
I have posted part of your program below. You need to add
the lines which are shown in bold. This will fix the problems
listed above.
Also I have one more comment. You are using "standard i/o"
which is the default mode for the compiler. In that mode, if you
use the built-in CCS functions such as output_low(), output_high(),
etc., the compiler will automatically insert code to setup the TRIS
register for an i/o port before it is written to. So you don't need
to use the set_tris_a() function in your program below. If you were
using the "fast_io" mode, then you would need it.
#byte ADCON0 = 0x1F
#byte ANSEL = 0x9F
#byte CMCON = 0x19
int16 Value=300;
ADCON0 = 0; // ADC off
ANSEL = 0; // GPIO pins 0,1,2 and 4 set to all digital
CMCON = 7; // Comparators off
set_tris_a(0b00000111);//RA0, RA1, RA2 as Inputs |
moritz
Posted: Sat Jul 03, 2004 6:22 pm |
Thanks a lot for your help so far. I've included the lines in my code as below. Unfortunately the program still hangs up on the line
Value=read_adc();
I'm really totally lost now, any more ideas what might be wrong?
Thanks, Moritz.
#include <12F675.h>
#device ADC=10
#byte ADCON0 = 0x1F
#byte ANSEL = 0x9F
#byte CMCON = 0x19
int16 Value=300;
//set_tris_a(0b00000111);//RA0, RA1, RA2 as Inputs RA3, RA4, RA5 as Outputs
set_adc_channel(0);
output_high(pin_a5);
delay_ms (250);
output_low(pin_a5);
delay_ms(10);
Value=read_adc();
delay_ms(10);
delay_ms (250);
output_low(pin_a4);
delay_ms(250);
delay_ms (1500);
output_low(pin_a4);
delay_ms(1500);
Posted: Sat Jul 03, 2004 11:46 pm |
I looked at it a bit further, and for vs. 3.091 with the 12F675, all
of the following A/D functions are completely screwed up.
They use registers and bit positions that are intended for the 16F877.
It can't possibly work.
setup_adc_ports();
setup_adc();
set_adc_channel();
read_adc();
If I feel energetic tomorrow, I'll work on coming up with some
revised functions that fix it for you. |
moritz
Posted: Sun Jul 04, 2004 4:37 am |
Dear PCM programmer,
just to say thank you for your help. I had a look through my disk collection and found another copy of the compiler, which is version 3.180. I installed it , compiled the program and it works.
For anyone who would like to try it out:
Thanks again, Moritz.
Code: | #include <12F675.h>
#device ADC=10
#byte ADCON0 = 0x1F
#byte ANSEL = 0x9F
#byte CMCON = 0x19
int16 Value=300;
setup_adc_ports( AN0_ANALOG );
set_adc_channel(0);
delay_ms (250);
output_low(pin_a5);
delay_ms(10);
Value=read_adc();
delay_ms(10);
delay_ms (250);
output_low(pin_a4);
delay_ms(250);
delay_ms (1500);
output_low(pin_a4);
delay_ms(1500);
// Connections:
// PIN 1 to VCC
// PIN 4 10K to VCC
// PIN 5 n.c.
// PIN 6 n.c.
// PIN 8 to GND
