Userrr Guest
Freq measure |
Posted: Wed Jun 23, 2004 10:11 am |
HELP me with link to freq meter by CCS. (with comments) |
dvsoft
Posted: Wed Jun 23, 2004 1:11 pm |
bonjour,
#include <18F452.h>
#device adc=8
#use delay(clock=40000000)
#fuses NOWDT,WDT128,H4, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN,NODEBUG, LVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
// CCP1 Data
int16 CCP1Value;
int16 CCP1OldValue;
BOOLEAN CCP1Captured;
#int_CCP1
CCP1_isr()
CCP1Value = CCP_1 - CCP1OldValue;
CCP1OldValue = CCP_1;
CCP1Captured = TRUE;
void HWInit(void)
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
//--- Setup de CCP1
setup_ccp1(CCP_CAPTURE_RE);
//--- Timer 1 for CCP1
//--- CCP1 Data
CCP1Value = 0;
CCP1OldValue = 0;
//--- CCP1 Interrupt
enable_interrupts(INT_CCP1);
//--- Global Interrupt
float Freq;
HWInit();
printf("Frequence test:\r\n");
while (TRUE) {
//--- CCP1 Captured ?
if (CCP1Captured) {
// F = 1/T
// Timer1 prescaler DIV_BY_8
// Pic18F452 at 40Mz -> 0.00000010 * 8
Freq = 1.0/((float)CCP1Value*8e-6);
printf("Freq:%f\r\n",Freq);
CCP1Captured = FALSE;
}// End IF
}// End While
Voila bon courrage
Alain |
Userrr Guest
Thanks |
Posted: Thu Jun 24, 2004 9:19 am |
Thanks dvsoft |
Userrr Guest
max frequency |
Posted: Tue Jun 29, 2004 10:06 am |
tell me max frequency for using CCP and 40Mhz ?
How me measure 50Mhz using timer? |
Simon Martineau
Posted: Tue Jun 29, 2004 12:25 pm |
You must understand that you are not mesuring directly the frequency but calculating it from the period (f=1/T). The way you measure the period is by counting how many cycles at 40MHz will be completed in a complete period. This way, it is completely impossible to measure a 50 MHz frequency. You can only know the frequency is higher than 40 MHz because of the count (1 sometimes and 0 sometimes). The max frequency depends on the prcesion you need. As an example, a 7MHz frequency can read 6.6MHz or 8MHz. If it i acceptable for your application, nice. Otherwise, you will need to lower the max frequency to get an acceptable error margin.
I might be wrong but that's what I think about the subject. If you find a way to measure a frequency higher than your base clock, I'd be very interested to know it.
Simon Martineau |
frequency counter |
Posted: Tue Jun 29, 2004 12:32 pm |
The only way it can be done is to condition the signal then feed it to a prescaler (i.e divide by 2, 4 etc) then make the freq measurement and multiply the result.
There are numerous examples out there:
Here is one 50MHZ unit based on the PIC.
http://www.web-ee.com/Schematics/FrequencyCounter/frequency_counter.htm |
Userrr Guest
But |
Posted: Tue Jun 29, 2004 2:25 pm |
But were I can found CCS example |
Freq Counter |
Posted: Tue Jun 29, 2004 3:34 pm |
The CCS example file (NOT an accurate 50MHZ freq counter) is EX_FREQC.C in the PICC/examples directory after you install the software.
If you dont have it and you have a licensed/registered copy of the compiler you will have to contact CCS via email and they will send it to you.
One word of caution, since this is for signals coming in on pin C0 it will not work will all types of signal waveforms and you cannot exceed the pin input maximum voltage or it will damage the chip! As I stated earlier you need some type of conditioning input circuit. |
testing Guest
Posted: Wed Aug 18, 2004 12:43 pm |
Code: | #include <18F452.h>
#device adc=8
// CCP1 Data
int16 CCP1Value;
int16 CCP1OldValue;
#int_CCP1
CCP1_isr()
void HWInit(void)
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
//--- Setup de CCP1
//--- CCP1 Data
CCP1Value = 0;
CCP1OldValue = 0;
float Freq;
HWInit();
while (TRUE) {
if (CCP1Captured) {
// F = 1/T
}// End IF
}// End While
