donnie
Joined: 13 Nov 2003 Posts: 12 Location: Kissimmee Florida
Unstable AD readings |
Posted: Tue Jun 29, 2004 10:01 am |
Has anyone had a problem with port to port isolation ?
I have 10K pullup resistors on the A0,A1,A3 ports.
When a voltage changes on A3 it also changes the value of A0 port.
Thanks,
Donnie |
rwyoung
Posted: Tue Jun 29, 2004 12:47 pm |
Are you allowing enough time to pass between switching channels for the S&H capactor inside the PIC to charge/discharge to the new level?
Why did you decide you needed pull-up resistors on your ADC inputs? _________________ Rob Young
donnie
Posted: Tue Jun 29, 2004 1:00 pm |
Iam using delay_ms(100)
If you apply the voltage from the AD8313 to Channel 4 all the channels change.
Donnie
Here is my code:
[co#include <16F876.h>
#fuses XT,NOWDT,NOPROTECT,NOPUT,NOBROWNOUT,NOLVP
#DEVICE ADC=10
#include <stdio.h>
#include <math.h>
#include <lcd1.c>
////////////////// START HERE /////////////////////////////
char k;
int16 RAW1;
int16 RAW2;
int16 RAW3;
int16 RAW4;
int16 data1;
int16 data2;
int16 data3;
int16 data4;
//setup_counters( RTCC_INTERNAL, RTCC_DIV_256 | RTCC_8_BIT);
setup_adc_ports( A_ANALOG_RA3_REF );
CCP_OFF;
lcd_init();
do{
//////////////////////// CHANNEL 1 //////////////////////
set_adc_channel( 0 );
RAW1 = Read_ADC();
//data1 = 2.25 * RAW1 - 902.5;
///////////////////////// MATH ///////////////////////////
//// .5V = 1mw and 2V = 250mw, Reference = 2.4V ////
//// (.5V) = 1024 * .5 / 2.4 = 192 Counts ////
//// (2V) = 1024 * 1.75 / 2.4 = 747 Counts ////
//// Assume a linear sensor: The conversion from ////
//// Counts to mW is as follows: ////
//// Slope(m) = (250 - 1) / (803 - 201) = ..414 ////
//// Offset(b) = 250 - .414 (803) = -82.44 ////
//// So mW = 0.414 * counts - 82.44 ////
data1 = (RAW1 + (data1 * 15)) / 16;
data1 = .890 * RAW1 - 337.58;
If (data1 >= 552)
data1 = 0;
data1 = data1;
delay_ms(10);
///////////////////////// CHANNEL 2 //////////////////////
set_adc_channel( 1 );
RAW2 = Read_ADC();
data2 = (RAW2 + (data2 * 15)) / 16;
data2 = 0.890 * RAW2 - 337.58;
If (data2 >= 552)
data2 = 0;
data2 = data2;
delay_ms(10);
///////////////////////// CHANNEL 3 //////////////////////
set_adc_channel( 2 );
RAW3 = Read_ADC();
data3 = 0.414 * RAW3 - 82.44;
If (data3 >= 552)
data3 = 0;
data3 = data3;
delay_ms(10);
///////////////////////// CHANNEL 4 //////////////////////
set_adc_channel( 4 );
RAW4 = Read_ADC();
data4 = 0.414 * RAW4 - 82.44;
If (data4 >= 552)
data4 = 0;
data4 = data4;
delay_ms(10);
//////////////////// DISPLAY /////////////////////////////
lcd_gotoxy(1,1);
printf(lcd_putc,"CH1:%3LumW", data1);
lcd_gotoxy(10,1);
printf(lcd_putc," CH2:%3LumW\n", data2);
printf(lcd_putc,"CH3:%3LumW", data3);
lcd_gotoxy(10,2);
printf(lcd_putc," CH4:%3LumW", data4);
///////////////////////// END ////////////////////////////
} while(true);
de][/code] |
rwyoung
Posted: Tue Jun 29, 2004 1:15 pm |
Your code looks OK but I dont' see a call to setup_adc() to configure the Tad time. You probably need at least ADC_CLOCK_DIV_8 if that is available in the header file.
Why did you decide to use pull-up resistors on an ADC input?
Is your Vdd level drooping or sagging when you apply your test voltage to AN3? Is the voltage on AN0 changing just a little bit, a lot or is it equal to AN3? _________________ Rob Young
donnie
Posted: Tue Jun 29, 2004 1:18 pm |
No drooping or sagging. But when i feed rf into the AD8313 Channel 1 port, you can see the voltage on channel 2 port change.
The 10K resistors are there to help make it stable incase the AD8313 goes bad.
Donnie |
rwyoung
Posted: Tue Jun 29, 2004 1:23 pm |
Ok, I saw your setup_adc() statement. Duh, can't read today. But I would still change it from _CLOCK_INTERNAL to CLOCK_DIV_something and see if that helps.
Also, if you look at the outputs of your AD8313 when they are NOT connected to the PIC ADC pins, do you see the same problem? Could you be coupling signal through the power supplies of the log-amps? _________________ Rob Young
donnie
Posted: Tue Jun 29, 2004 1:30 pm |
When i take the 8313 chip out it goes to zero and the voltage don't change may have to add some caps to the signal line.
I just don't want to clamp down to much.
Donnie |
xav27 Guest
ADC problem |
Posted: Tue Jun 29, 2004 1:36 pm |
Hello Donnie,
in your code you have define RA3 to be the ref for the ADC !
So I think this is normal that when you change that ref. (RA3) this other input change to !?
part of 16f876.h
#define A_ANALOG_RA3_REF 0x83 // A0 A1 A2 A5 Ref=A3
hope I help you
Xavier |
donnie
Posted: Tue Jun 29, 2004 1:53 pm |
Is there a way to get it to work without the RA3 REF?
Thanks,
Donnie |
Posted: Tue Jun 29, 2004 2:13 pm |
donnie wrote: | Is there a way to get it to work without the RA3 REF?
Thanks,
Donnie |
You can use
setup_adc_ports(RA0_RA1_RA3_ANALOG);
Check your device spec for:
#define RA0_RA1_RA3_ANALOG 0x84 // A0 A1 A3 Ref=Vdd
Johny |
