Logical OR operator, how?
sir_mane
PostPosted: Tue Jun 29, 2004 12:07 am     Reply with quote
Hi.
Simple question; what is wrong?
if (( A==1 ) && (( B==1 ) ll ( C==1 )))
error: Expecting a close param
Embarassed
How OR operator works?
Regards
Sir_mane
PostPosted: Tue Jun 29, 2004 12:41 am     Reply with quote
You don't have the "vertical line" character in there.
You've got lower-case "LL" in there. You can see
this if you display that line with the Code tags on
this board. The Code tags use the Courier font:
You need to use a font in your C editor that shows the
difference between between a lower-case L and
the vertical line symbol. Don't use Arial.
Use Courier or Fixed Sys or something like that.
sir_mane
Thanks.
PostPosted: Tue Jun 29, 2004 12:50 am     Reply with quote
I copy => paste that from ccs help
and it give ll ( lower-case "LL" ).
so I didn't know that it should be
Now it's working.
Thank you PCM programmer
Again...
Laurent Chouinard
PostPosted: Tue Jun 29, 2004 11:20 am     Reply with quote
In my opinion, the best font for coding:
Profont
Of course, for this one, it's recommended to have an LCD display or a CRT of good quality (sharp). With this font you can pack quite a lot of highly readable code at 8-pixels size, and it shows all the similar characters to be quite different, like the number one, the letters i and L.
