Soldering down PLCC PICs
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Sat Jun 26, 2004 10:08 am     Reply with quote
Is it regarded good practice to solder down PLCC PIC’s? I was planning to use the TQFP package but they are considerably more expensive that the PLCC package. I’ve only used them in sockets before but this design is on a budget!
Will
rnielsen
PostPosted: Sun Jun 27, 2004 12:07 am     Reply with quote
If the PIC will be installed permanently, then sure. It will make upgrading the software more dificult, unless you are going to do in-circuit programming. The only reason you want to 'socket' the PIC is for upgrades or proto-typing. Soldering is definately more reliable, in my opinion.
Ronald
MikeW
PostPosted: Sun Jun 27, 2004 1:27 am     Reply with quote
PLCC is fine if you are having the boards made by a professional company.
I assume that the rest of the components are also smd, so the boards will be manufactured using pick and place machines, and soldered by machines as well.
Hand soldering PLCC packages is not suitable, since the contact between board and pin is underneath the plastic.
I have soldered PLCC for a prototype, but it is hit and miss
Mike
Will Reeve
PostPosted: Sun Jun 27, 2004 1:05 pm     Reply with quote
PLCC it is then. At over 1UKP cheaper than the TQFP part! But why do Microchip have such a "random" policy of pin numbering, they could at least keep the numbers the same between the 44pin packages!
rnielsen
PostPosted: Sun Jun 27, 2004 9:40 pm     Reply with quote
There are some standard packages that have been established but not all of the IC's that are designed have the same count I/O. They simply select the packages that they want to incorporate in their product and then do the best with what has been laid out.
Ronald
jventerprises
soldering PLCCs
PostPosted: Mon Jun 28, 2004 10:16 am     Reply with quote
i solder the PLCCs reliably all the time (for customers), BUT i have a 10x optical scope to do it AND a Metcal iron with an appropriate tip. still, it takes some time and is easy to short adjacent pins.
buy the TQFP and save yourself time and annoyance!
Jon
SherpaDoug
PostPosted: Mon Jun 28, 2004 11:02 am     Reply with quote
I have hand soldered 44pin PLCC packages for years for US Navy and other marine customers without any problems. I even remove and replace chips. Just keep things clean, hot (750), and fast. I use a common Weller WES50 iron with a fine flat tip. I use a glass for inspection afterward. Soldering using a glass is a pain due to bad depth perception.
Kasper
PostPosted: Mon Jun 28, 2004 12:20 pm     Reply with quote
Solder braid is your friend for doing fine pitch soldering. I often solder on chips with down to 0.5mm pitch by hand using a regular weller iron. shorts all over, then clean up with solder braid, mop up the left over flux and it looks machine done Smile for inspecting for shorts, magnification and holding up the board against a light source and you can see even the smallest shorts.
PostPosted: Mon Jun 28, 2004 12:31 pm     Reply with quote
Pace has some short QuickTime videos which show to solder PLCC
packages by a variety of methods. Just click on the links that say Video.
http://www.paceusa.com/_ApplicationSubList.asp?ApplicationGroupID=7#
SteveS
PostPosted: Mon Jun 28, 2004 12:39 pm     Reply with quote
- And I thought I was the only one doing that (well maybe not the machine done look)Wink We have an assembler that does even the real fine pitch all by hand and it's beautiful. I normally stop at 0805 and SOIC parts and let him take over.
jventerprises
solder braid
PostPosted: Mon Jun 28, 2004 12:55 pm     Reply with quote
i agree with the solder braid trick. just solder away and clean it up afterwards with the braid. i do that too. just be careful not to over heat the part. its real easy to do with braid. you can damage some of the smaller parts by applying too much heat.
solder braid does leave a lot of flux residue, so you might want to clean the boards after.....
Jon
SherpaDoug
PostPosted: Mon Jun 28, 2004 2:06 pm     Reply with quote
The Pace video shows soldering one pin at a time in sucession with an iron. I prefer to solder every other or every third pin first, and come back for the others on later passes. My theory is that it reduces the thermal stress. Like tightening the lug bolts on a wheel it is better to apply the stress evenly than to completely stress one area and then an adjacent area. You can end up with one side of the chip very hot while the others are still cool.
Just my gut feel.
