problematic array
adrian
problematic array
PostPosted: Fri Jun 25, 2004 4:08 pm     Reply with quote
I have a question on how to increment an array.
First the important stuff:
PCM 3.148
12F629
I have an array which I initialise thus:
// all variables are global \\
//numbers
#define   ZERO            0x7E
#define   ONE            0x0C
#define   TWO            0xB6
#define   THREE            0x9E
#define   FOUR            0xCC
#define   FIVE            0xDA
#define   SIX            0xFA
#define   SEVEN            0x0E
#define   EIGHT            0xFE
#define   NINE            0xDE
//LCD display
int   digits[10]   =   {ZERO,ONE,TWO,THREE,FOUR,FIVE,SIX,SEVEN,EIGHT,NINE};
int   digit_counter    =   0;   //used to keep track of displayed digit
int   bit_counter   =   0;   //used to keep track of bits within each digit
It is used in the main loop
while (TRUE)
   //cycle through digits 0 -> 9
      for   (;   digit_counter <=9;   digit_counter++)
         //increment array
            digits[digit_counter];
         //set clock low
         output_low(S_CLK);
         //clock bits out from the array element
         for   (;   bit_counter <=7; bit_counter++)
            output_bit(S_DATA,shift_right(digits,1,0));
            //clock bit out
            output_high(S_CLK);
            delay_cycles(1);
            output_low(S_CLK);
         //reset bit_counter
         if   (8 == bit_counter)
            bit_counter = 0;
What I am trying to achieve, is to clock each element of the array serially out through a port pin. It will work the first time as 'digit_counter' is initialised at 0, and I can see the code running as I expect it to via the simulator. However I cannot get the next element of the array to load. I was hoping to use 'bit_counter' to index the elements of the array?
The code compiles and when I run it through the simulator it steps over the line.... digits[digit_counter]; which I hoped was going to increment the array?
Looking at the .lst there is no code shown for this line?
Its getting late and I've probably done something silly - its just that I cant see it. All suggestions gratefully received.
PostPosted: Fri Jun 25, 2004 5:05 pm     Reply with quote
         //increment array
This line is doing nothing, you are reading a value but don't do anything with it. Your compiler has optimized it away, that's why your simulator is stepping over it.
One possible solution is to change this line to
          new_digit = digits[digit_counter];
and then also change
to
output_bit(S_DATA,shift_right(new_digit,1,0));
dvsoft
PostPosted: Sat Jun 26, 2004 1:40 am     Reply with quote
Bonjour,
you can try this code
// SPI I/O
#ifndef __SPI_IO__
#USE fast_io(c)
#define SPI_SO PIN_A5
#define SPI_SI PIN_A4
#define SPI_SCK PIN_E0
#endif // __SPI_IO__
// Your DATA
#define ZERO 0x7E
#define ONE 0x0C
#define TWO 0xB6
#define THREE 0x9E
#define FOUR 0xCC
#define FIVE 0xDA
#define SIX 0xFA
#define SEVEN 0x0E
#define EIGHT 0xFE
#define NINE 0xDE
//LCD display
// public :
// Function :Write_SPI
// Version :0.1
// Author :Alain
// Usage :write_SPI(Data)
// Arguments:BYTE Data Data to write
// Return :void
// Modify :void
// Shifts out on the falling edge of the clock.
void write_SPI(BYTE Shift)
BYTE BitCnt = 8;
//--- Shifts out
do {
//--- Clock low
output_low(SPI_SCK);
//--- Bit = 1
if(Shift & 0x80)
output_high(SPI_SO);
//--- Bit = 0
output_low(SPI_SO);
Shift <<= 1;
//--- Clock high
output_high(SPI_SCK);
} while (--BitCnt);
#ifdef __TEST__
int8 ByteCnt;
//--- Loop Test 1
for (ByteCnt = 0; ByteCnt < 10; ByteCnt++)
//--- Output the Current Byte
Write_SPI(digits[ByteCnt]);
//--- Loop Test2
ByteCnt = 0;
while (ByteCnt < 10)
Write_SPI(digits[ByteCnt++]);
//--- Loop Test3
ByteCnt = 0;
do {
} while (++ByteCnt < 10);
#endif // ___TEST__
bon courrage
Alain
adrian
PostPosted: Sat Jun 26, 2004 2:19 am     Reply with quote
ckielstra wrote:
         //increment array
OK that explains it.
I had assumed - wrongly, that as the for loop was being incremented, the array element would also be incremented as I was using the same variable.
