Redirecting RS232 data using HW and SW USART on PIC18F4220
jpage
PostPosted: Wed Jun 23, 2004 9:27 am     Reply with quote
I am interfacing with a device connected to a PIC18F4220 and want to communicate with the device by using RS232 from a Host computer.
The device is connected the PIC18F4220 using pins B2 and B1.
B1 is reading data transmitted from device and B2 is sending data to device.
I am using the onboard USART to communicate with the Host computer via RS232 on pin C6 and C7.
I want to take the data on pins B2 or B1 and redirect the data to or from the USART.
I would appreciate any feedback on any methods to accomplish this. Thanks.
PostPosted: Wed Jun 23, 2004 2:02 pm     Reply with quote
What is the communication standard used on Pins B1 and B2 ?
Is it i2c, or RS232, or something else ?
Does the data from this "device" arrive in 8-bit bytes ?
PostPosted: Wed Jun 23, 2004 2:45 pm     Reply with quote
Communications for the device on pins B1 and B2 is RS232.
And yes it does transfer data in 8 bit Bytes.
I have had the device connected directly to my computer serial (COM1) and am able to transfer data with no problem.
Only this time, I will need to go through the PIC's USART and redirect to the data through pins B1 and B2. This is where I need some ideas in how to accomplish this.
dyeatman
Redurect B1/B2
PostPosted: Wed Jun 23, 2004 3:18 pm     Reply with quote
What you want to do can't be done to my knowledge. What I have done in the past is use an RS232 multiplexer chip to switch B6/B7 between multiple RS232 sources. I did this to service 5 different LCD displays and it worked fine. The only limitations are that you cant have the different channels transmitting/receiving at the same time and they must all be the same bits/stop bits. You have to service them sequentially to use the mux..
Your only other option is to use a chip with two hardware USARTS.
