Guest Guest
Included header files |
Posted: Mon Jun 21, 2004 5:40 am |
As a newbe to the CCS compiler, I have a problem with including a main.h with a main.c.
For some reason the compiler does not recognise or accept the contents of the header file resulting in spurious error messages such as undefined type and no such function.
It seems if I include the contents of the header file main.h in main.c and delete main.h or the contents of main.h then there is no problem. I no not normally have this problem with other compilers such as borland, MSVC++ and GNU.
reply much appricated. |
Posted: Mon Jun 21, 2004 2:24 pm |
I made a test program, and it worked OK. I compiled this
with PCM vs. 3.202 and used MPLAB vs. 6.42.
I made a new project named "Main", and added the main.c
source file to the "Source Files" section in the Project window.
MPLAB picked up Main.h during the compile, and added it
to the "Header Files" section by itself. I got one warning
about "Condition always True" during the compile. That's OK.
I suggest that you try this test program, and see if it works.
The following code is in main.c
Code: | #include <16F877.h>
#use delay(clock = 4000000)
#include "main.h"
func1(MY_CONSTANT);
// FUNCTIONS
char func1(char c)
c += 5;
return(c);
The following code is in main.h
Code: | #define MY_CONSTANT 0x55
char func1(char c); |
Guest Guest
Is it case related? |
Posted: Mon Jun 21, 2004 6:55 pm |
Long time ago I has similar problem using various *.h files and it was related to case sensitivity. |
