lewiseley
write program eeprom |
Posted: Sun Jun 20, 2004 1:01 pm |
having dificulty writing to program eeprom
i have a routine that
reads the code space into a buffer
copies the bits needed to be updated into it
and then writes it back with write_program_eeprom
then loads the next block of code in to the buffer
and does so until all data is updated
if i make the buffer large enough for all the data in one hit it works wonderfull
if i make the buffer small, sections get erased and it is most confusing
i have tried 32 byte 64 byte both of which cause loss of data
but 128 ( big enough for one hit ) it works.
im using icd2 ccs 3.202 & 18f252 processor with 8mhz clock + PLL
anybody got any idea's.
the code is pretty simple, cant understand why it wont work.
( at my wits end )
lewis. |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Sun Jun 20, 2004 5:08 pm |
Post your code... |
Neutone
Posted: Sun Jun 20, 2004 7:54 pm |
What your doing is very much like a boot loader. You may find some technics that work looking at the code that they use. I have never used a bootloader but that is how I would aproach the problem. |
lewiseley
ok heres my code |
Posted: Wed Jun 23, 2004 12:11 pm |
// a routine to store a meter control block.
int8 store_mcb ( int8 *mccb )
int8 const bufsize=64;
int8 i,bnk,ctr,signal,written; //general purpose counter
int8 tempx[bufsize]; //temporary storage
int32 addr,adr,ending,starting; //address where it lives.
int32 add_spec;
//disable_interrupts(global);
i=mccb[0]; //search for this mcb
fetch_mcb( &tempx[0],i,addr); //fetch the last address
// we know have the addr of the last byte of any mcb's
// test for already existent mcb and abort if exist
if ( tempx[0]==mccb[0])
if (tempx[1]!=mccb[1]) //if they differ in size
return mcb_size_wrong; //sizes differ so exit
//although may already exist if sizes are same then ok to overwrite
read_program_memory(0x280,tempx,bufsize); //read in the first block.
starting=addr; //calculate the start address
ending=starting+mccb[1]; //calculate the end address
signal=0;
bnk=0;
tempx[0]++; // increase the number of defined blocks
written=1; //to cause the write back of new maxblocks
for ( adr=0x280;adr<0x400;adr++) // do for each byte of the address
signal=0; //default to no replacement
if ( adr>=starting)
signal=1;
if ( adr>ending)
signal=0; // turn off the copying process
if (signal==1)
tempx[(adr&(bufsize-1))]=mccb[adr-starting];
written=1;
} //end of signal
if ( (adr&(bufsize-1))==(bufsize-1))
{ // now we write back the block and fetch the next one
if (written==1)
//add_spec=(0x280+(bnk*bufsize));
if (bnk==0)
write_program_memory(0x280,tempx,bufsize);
if (bnk==1)
write_program_memory(0x2c0,tempx,bufsize);
if (bnk==2)
write_program_memory(0x300,tempx,bufsize);
//write_program_memory(add_spec,tempx,bufsize); //write the bank in place
written=0;
bnk++; // inc bank number
//add_spec=0x280+(bnk*bufsize);
if (bnk==0)
if (bnk==1)
read_program_memory(0x2c0,tempx,bufsize);
if (bnk==2)
read_program_memory(0x300,tempx,bufsize);
} // end of the for loop
// delay_ms(1000);
// enable_interrupts(global);
return ok;
} // end of store meter control block.
fetch_mcb just looks through memory and returns the address where it
already lives if updating or the next spare address to start writing at.
it should work, i have messed with it somewhat, but can not get it to work
as intended, i start writing from 0x280 i have a problem if i am trying to write over two blocks of 64, 0x2b0 .. 0x2c0 blocks, it seems to write the 0x2b0 block and and 0x2c0 block, but say - if the next address spare to write at ( the next time the routine is called ) say 0x2c8 the write from 0x2c8 onwards is o.k but the bytes from 0x2c0 .. 0x2c7 get turned into
0xff, and it shouldnt do that. the blocks that i write can vary in size, but forcing them to always be an even size makes no difference.
what do you think |
