dlee425 Guest
Voltage Conversion |
Posted: Wed Jun 16, 2004 2:47 pm |
Got my system all running.
I have a question about voltage to decimal conversion.
On the ADC input iam using .5 to 1.75V but on the display it
read decimal. I would like to know if there is a formula to convert
the incoming voltage to a readable voltage on the display.
Donnie Lee |
Almost forgot. |
Posted: Wed Jun 16, 2004 2:56 pm |
Unit is setup int16
it goes from 0 to decmial1023
Thanks |
Re: Voltage Conversion |
Posted: Wed Jun 16, 2004 3:01 pm |
dlee425 wrote: | Got my system all running.
Donnie Lee |
The ADC (depending on the chip involved), returns a binary value, from 0-1111111111 (for the '10bit' converter which is the commonest type), for a voltage range of 0v to Vref (in fact a voltage of Vref itself would correspond to 10000000000, but the converter stops at just 10 bits).
So the answer will depend on what Vref is being used.
If the internal nominal 2.5v reference, and a 0.5v input, you should get a value of:
0.5/(2.5/1024) = 205 (in decimal)
for 1.75v, you should get:
1.75/(2.5/1024) = 717
The last bit or two will depend on noise, the charge time allowed for the input capacitor, and some luck. To convert back for display, if you have the read voltage in a long integer called 'Vin', use:
printf("The voltage is %f/n",(float)Vin*0.0024414);
Which is the based on the inverse of the above arithmetic.
Posted: Thu Jun 17, 2004 6:33 am |
I have the 16F876 Chip set for 10 bits
Thanks |
Setup |
Posted: Thu Jun 17, 2004 6:46 am |
Ok its the 16f876 driven by a AD8313 log chip.
I have port a setup as all_analog.
the ref is 5v
so 1.75V input would be 2.75/(5/1024)=358 decmial
What i need to do is convert the 358 decmial to read Power in mw.
Say 358 decmial = 250mw
Thanks,
Donnie Lee |
SteveS
Posted: Thu Jun 17, 2004 8:16 am |
If you got space and time then you could simply ( I assume a zero offset and linear sensor):
float fdata;
float factor;
factor = 250.0 / 358.0; // conversion - (this could be a define)
fdata = (float) data; // convert ADC to float (data is raw ADC value)
fdata *= factor; // convert to mW
data = (int16) fdata; // convert to int (if desired)
'course when I was a kid we had to walk to school in 2K bytes EPROM and 32 bytes of RAM so I would be tempted to use:
data *= 45; // data * (factor * 64)
data = data >> 6; // data /= 64;
Huh? Well the factor to convert counts to mW is 250/358 = 0.698. We save time and space by staying in integers and avoiding division. We avoid divison by making our division a shift ( divide by a power of 2). So we convert 0.698 to some a fraction x/(2^n). Since your ADC value can be as high as 1024, x must be less than 2^16 (int16)/1024 = 64. So .698 * 64 = 44.7 which we round to 45. This method will not be exact so it may not be accurate enough for you. You can get better accuracy by making 'n' larger, but then you need better than 16 bit math. In that case use 32 bit math and use n = 8; The shift is now a whole byte, so you just ignore the lowest byte of the multiplication result.
- SteveS |
Voltage To Mw |
Posted: Thu Jun 17, 2004 10:00 am |
That got it. Now I have a 4 input millwatt meter.
Thanks for all the help..
Donnie Lee |
Posted: Thu Jun 17, 2004 11:55 am |
I got the system to work.
I would like a better res on the meter.
100mw = 1.400V
150mw = 1.432V
etc.
So its .00064V per mw (.032 / 50) = .00064V per mw
its there a way to read the lower 3 bits to get a higher res.
Sorry for al the dumb questions, but iam new at this and have learned a lot from you people on coding.
Thanks,
Donnie |
SteveS
Posted: Thu Jun 17, 2004 2:53 pm |
First, these are not dumb questions. You are making good progress each time you come up with a new question - so keep going.
Second - You should go ahead and join the list, it's nice to have a 'handle' so we know it's you each time.
Third - your question:
Looking through your posts I get the following:
1. Your input can range from 0.5 to 1.75 Volts
2. You are using a 5V reference
As Ttelmah explained, your resolution will depend on your reference. The 16F876 can have Vref+ to Vref- as low as 2.0V. With a 5V reference you are wasting a lot of teh converterd range. Your range is pretty close 2.0V that, so I would try to use a 2.0V reference - 2.048 is popular as it makes the 10 bit converter output = 2.048/1024 = 2mV per bit. Another way to get better resolution is offset and amplify the signal so it's range equals the reference, but that adds complexity and perhaps error. If 2mV per bit is good enough then I would go that way. Of course we are assuming the converter has no error, etc, but this shows you the limit as to what you can expect. 2mV resolution is ~3mW - is that ok?
- SteveS |
donnie
Joined: 13 Nov 2003 Posts: 12 Location: Kissimmee Florida
Posted: Fri Jun 18, 2004 6:41 am |
I still can not get .5V to display 1mw.
Here is my code, I know iam missing something but can't figure out what.
Ref Voltage is 2.41V on RA3
Inout is .5 (1mw) to 1.75 (250mw)
#include <16F876.h>
#fuses XT,NOWDT,NOPROTECT,NOPUT,NOBROWNOUT
#DEVICE ADC=10
#include <stdio.h>
#include <math.h>
#include <lcd1.c>
////////////////// START HERE /////////////////////////////
char k;
int32 data1;
int32 data2;
int32 data3;
int32 data4;
float fdata1;
float fdata2;
float fdata3;
float fdata4;
float factor1;
float factor2;
float factor3;
float factor4;
setup_counters( RTCC_INTERNAL, RTCC_DIV_256 | RTCC_8_BIT);
setup_adc_ports( A_ANALOG_RA3_REF );
CCP_OFF;
do{
//////////////////////// CHANNEL 1 ////////////////////////
set_adc_channel( 0 );
delay_ms(200);
data1 = Read_ADC();
factor1 = 250.0/604.0; // Cal Point For CH1:
fdata1 = (float)data1;
fdata1 *= factor1;
data1 = (float)fdata1;
data1 *= 45; // data * (factor * 64)
data1 = data1 >> 6; // data /= 64;
delay_ms(200);
//////////////////////// CHANNEL 2 ///////////////////////
set_adc_channel( 1 );
delay_ms(200);
data2 = Read_ADC();
////////////////////////// MATH //////////////////////////
factor2 = 250.00/302.08; //Cal Point For CH2:
fdata2 = (float)data2;
fdata2 *= factor2;
data2 = (float)fdata2;
delay_ms(200);
///////////////////////// CHANNEL 3 //////////////////////
set_adc_channel( 2 );
delay_ms(200);
data3 = Read_ADC();
//////////////////////// MATH ////////////////////////////
factor3 = 250.00/302.08; //Cal Point For CH3:
fdata3 = (float)data3;
fdata3 *= factor3;
data3 = (int16)fdata3;
delay_ms(200);
///////////////////////// CHANNEL 4 //////////////////////
set_adc_channel( 4 );
delay_ms(200);
data4 = Read_ADC();
/////////////////////// MATH /////////////////////////////
factor4 = 250.0/ 302.08; //Cal Point for CH4:
fdata4 = (float)data4;
fdata4 *= factor4;
data4 = (int16)fdata4;
delay_ms(200);
//////////////////// DISPLAY /////////////////////////////
//printf(lcd_putc,"\f");
printf(lcd_putc,"\fCH1:%Lumw", data1);
lcd_gotoxy(10,1);
printf(lcd_putc," CH2:%LumW\n", data2);
printf(lcd_putc,"CH3:%Lumw", data3);
lcd_gotoxy(10,2);
printf(lcd_putc," CH4:%LumW", data4);
///////////////////////// END ////////////////////////////
} while(true);
donnie
Please Help |
Posted: Fri Jun 18, 2004 8:08 am |
Thanks for any help you can give a newbie..
Donnie |
SteveS
Posted: Fri Jun 18, 2004 9:08 am |
Ok - let's see:
1. In all the channels you use (using ch 1 as the example):
That should be:
data1= (int16)fdata1;
It probably converts it right anyway, but might as well have the code reflect what happens.
2. I gave you two ways to do the math. One in floating point; the other using integer math. In the channel one routine you use both. I bet you were trying the two methods out, but one needs to be commented out.
3. You can move the constant factors out of the 'do' loop. You are recalculating them each time. No need. You could also declare them as constants:
const float factor1 = 250.0/604.0;
etc.
4. If you want the data to always be displayed in 3 spaces, right justified use:
%3Lu
in the printf.
5. I still haven't helped with your problem, unless it's due to #2 above...
If not, then :
.5V is 1024 * .5 / 2.41 = 212
* 250.0 / 302.08 = 175.8
(int16) = 175 - that's not 1mW
-- start from scratch:
you want .5 = 1mW and 1.75 = 250mW, reference = 2.41V
so, .5 = 212 counts (from above) , 1.75 = 1024 * 1.75 / 2.41 = 744
assume a linear sensor: the conversion from counts to mW is:
slope (m) = (250-1)/(744-212) = 0.468
offset (b) = 250 - 0.468 (744) = -98.2
so: mW = 0.468 * counts - 98.2
Try that.
- SteveS[/b] |
donnie
1mw |
Posted: Fri Jun 18, 2004 11:52 am |
Got it. Looks ok so far.
Thanks for all your help..
BTW: Now at looking at the math a few things are slowly coming back. Its hell to be getting old..
Donnie Lee |
