Is it possible to have interrupt on INT0 (in B0) on both edges?
thanks and regards
George
Neutone
Posted: Wed Jun 16, 2004 10:15 am
It is posiable but not suggested unless you have an incoming signal that has no glitches. It is posiable to trigger the low to high edge with noise Then when you switch detection method in the interupt your looking for the wrong edge. You have to change configuration in the interupt.
