Dumb-struct
Dumb-struct
PostPosted: Mon Jun 14, 2004 9:43 am     Reply with quote
Searched on "struct initialize" and didn't find much.
I tried to clean up a project (PCM 3.185 on a PIC16F877) that works fine. Wanted to put some of my constants in structures like:
struct axisconsts
float offset;
float sense;
} x_axis, y_axis;
x_axis.offset = 3.1459;
x_axis.sense = 2.71828;
.... and so forth.
The compiler complains that the line with x_axis.offset needs a "(". This is right out of the book, basically. What is wrong? Take out the struct initialization lines and it compiles fine.
Thanks.
LloydSargent
PostPosted: Mon Jun 14, 2004 9:57 am     Reply with quote
Hmm...
I tried it and it worked fine (not the answer you want to hear!).
Where do you have
In your code?
Cheers,
Lloyd
SteveS
You need to put the initializations inside a function or main.
-or initialize them like this (based on K&R)-
struct axisconsts
float offset;
float sense;
struct axisconsts x_axis = {3.1459 , 2.789 };
struct axisconsts y_axis = {1.23, 4.56 };
- SteveS
LloydSargent
PostPosted: Mon Jun 14, 2004 10:09 am     Reply with quote
Okay, before you get too confused, HERE are the only valid ways to initialize the struct.
1ST
struct axisconsts
float offset;
float sense;
struct axisconsts x_axis= {3.1459, 2.71828};
main()
2ND
struct axisconsts
float offset;
float sense;
} x_axis, y_axis;
main()
3RD
main()
  struct axisconsts
    float offset;
    float sense;
  } x_axis, y_axis;
4th
struct axisconsts
float offset;
float sense;
} x_axis= {3.1459, 2.71828};
main()
This is off the top of my head. I may have missed one...
Cheers,
Lloyd
Struct initialization
PostPosted: Mon Jun 14, 2004 10:39 am     Reply with quote
OK folks -
Thanks very much and let me try some of these suggestions.
Michael
