PICs with built-in I2C
SteveS
PostPosted: Sat Jun 12, 2004 9:47 am     Reply with quote
I did a search on Microchip's site to find what small 16F or 18F parts there were with built-in I2C. Maybe I'm missing something but they only show a few parts - all big parts or new ones. But I know there are others - so can anyone suggest the smallest 16F or 18F parts with built-in I2C - I need to do slave mode.
Meanwhile- I'm rambling thru the datasheets....
TIA,
SteveS
try this
PostPosted: Sat Jun 12, 2004 10:27 am     Reply with quote
pic18F242 or 252 the SPI doubles as I2C
hansw
ttelmah
Re: PICs with built-in I2C
PostPosted: Sat Jun 12, 2004 10:42 am     Reply with quote
TIA,
SteveS
The smallest 'current' parts with hardware I2C, that I can think of, is the 18F818/9, in 18 pin. Their search engine is awful in this regard, if you specify '<=28 pins', and 'I2C interface', it finds no parts, yet these exist...
rnielsen
PostPosted: Mon Jun 14, 2004 8:38 am     Reply with quote
I've used the following PIC's for I2C communications:
18F452(40 pin), 16F87(18 pin) and 16F76(28 pin).
SteveS
PostPosted: Mon Jun 14, 2004 9:47 am     Reply with quote
Thanks all -
When I went to Microchip site - it was 'cool, they added parameter look-up', but as ttelmah states, it is truly awful. I knew I had used other parts before that didn't show up. I feel sorry for someone new to PICs, they might do the search and just give up. I was hoping it was me and the way I searched, but no.
Now I get to try to make sense out of all the posts on slave mode problems...
- SteveS
PostPosted: Mon Jun 14, 2004 10:25 am     Reply with quote
SteveS wrote:
Thanks all -
- SteveS
The biggest core 'problem' I can think of is the damn long time it takes for the slave to respond to an interrupt, and be ready with a reply (assuming you are using a 'read' command). Just how long this truly is, especially if you have other interrupt handler, which the processor might be executing at the time, is a real 'pain' when you are used to hardware systems that can respond on the very next clock...
Combine this with a few 'oddities' in the way the CCS functions are structured, stir gently, and you have the core of most slave problems...
Hope you get it working how you want.
SteveS
PostPosted: Mon Jun 14, 2004 11:47 am     Reply with quote
Thanks for the heads up - it will be a write-only-device - I need to make an SPI peripheral look like an I2C peripheral. Thats why I was looking for min pins - only need 5 or 6...
- SteveS
