CHRIS Guest
COMPACT FLASH PROBLEM!!!! |
Posted: Thu Jun 10, 2004 4:45 am |
I am working with a CF card and I can read and erase sectors, but I can't write a sector and I don't know why.
I belive that my code is correct.
Do somebody detect the fail?
Thank's.
#include <16F73.h>
#fuses HS,NOWDT,NOBROWNOUT
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7)
#byte cf_control = 0x05 // puerto a
#byte cf_data = 0x06 // puerto b
#byte cf_addr = 0x07 // puerto c Solo usaremos C0,C1 y C2 para direccionar
#byte tris_cf_control = 0x85 // puerto a (1=entrada, 0=salida)
#byte tris_cf_data = 0x86 // b
#byte tris_cf_addr = 0x87 // c
#bit CE1 = cf_control.0
#bit CD1 = cf_control.1
#bit RESET = cf_control.2
#bit OE = cf_control.3
#bit WE = cf_control.4
#bit RDY = cf_control.5
#bit bucle = cf_addr.4
#bit led = cf_addr.3
//FOR UART
#byte SPBRG = 0x99 // BAUD RATE GENERATOR REGISTER
#byte TXREG = 0x19 // USART TRANSMIT DATA REGISTER
#byte RCREG = 0x1A // USART RECEIVE DATA REGISTER
#byte TXSTA = 0x98 // TRANSMIT STATUS AND CONTROL REGISTER
#bit CSRC = 0x98.7 // Clock Source (1=Master, 0=Slave) Modo SYNC
#bit TX9 = 0x98.6 //
#bit TXEN = 0x98.5
#bit SYNC = 0x98.4
//#bit--- = 0x98.3
#bit BRGH = 0x98.2
#bit TRMT = 0x98.1
#bit TX9D = 0x98.0
#byte RCSTA= 0x18
#bit SPEN = 0x18.7
#bit RX9 = 0x18.6
#bit SREN = 0x18.5
#bit CREN = 0x18.4
#bit ADDEN = 0x18.3
#bit FERR = 0x18.2
#bit OERR = 0x18.1
#bit RX9D = 0x18.0
// DIRECCION DE LOS REGISTROS DE LA COMPACT FLASH
// SOLO SON NECESARIAS 3 LINEAS:
// (X,X,X,X,X,A2,A1,A0)
#define DATA_REG 0x00 // ADDRESS OF DATA REGISTER
#define ERROR_REG 0x01 // ADDRESS OF ERROR REGISTER
#define FEATURES_REG 0x01 // ADDRESS OF FEATURES REGISTER
#define SEC_CNT_REG 0x02 // ADDRESS OF SECTOR COUNT REGISTER
#define SEC_NUM_REG 0x03 // ADDRESS OF SECTOR NUMBER REGISTER
#define CYL_LO_REG 0x04 // ADDRESS OF LOW CYLINDER REGISTER
#define CYL_HI_REG 0x05 // ADDRESS OF HIGH CYLINDER REGISTER
#define HEAD_REG 0x06 // ADDRESS OF HEAD/DRIVE REGISTER
#define STATUS_REG 0x07 // ADDRESS OF STATUS REGISTER
#define COMMAND_REG 0x07 // ADDRESS OF COMMAND REGISTER
// VALORES EN HEXADECIMAL DE COMANDOS PARA LA COMPACT FLASH
#define IDENTIFY 0xEC // IDENTIFICA LOS PARAMETROS DE LA UNIDAD
#define WRITE_SEC 0x30 // ESCRIBIMOS TANTOS SECTORES COMO INDICA SEC_CNT_REG
#define WRITE_BUFF_SEC 0xE8 // ESCRIBIMOS EN EL BUFFER TANTOS SECTORES COMO INDICA SEC_CNT_REG
#define READ_SEC 0x20 // LEEMOS TANTOS SECTORES COMO INDICA SEC_CNT_REG
#define ERASE_SEC 0xC0 // BORRAMOS TANTOS SECTORES COMO INDICA SEC_CNT_REG
//-------------------------------funciones usadas
void inicializa(void);
void cfwrite(void);
void cfread(void);
void checkready(void);
void getdatafromcf(int32 lba);
void putdatatocf(int32 lba);
void readsector(void);
void writesector(void);
void erasesector(void);
void getLBA(void);
//--------------------------------------end prototypes
char data_lo,data_hi,;
int32 LBA;
byte contador;
byte i;
char buffer_in;
void main() {
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
inicializa();
for (i=0;i<4;i++)
led = 1;
led = 0;
while(1){
buffer_in=getc();
switch (buffer_in){
case 0xF8: //READ SECTOR
getLBA();
getdatafromcf(LBA);
readsector();
case 0xF9: //WRITE SECTOR
getLBA();
putdatatocf(LBA);
writesector();
case 0xFB: //ERASE SECTOR
getLBA();
getdatafromcf(LBA);
erasesector();
delay_ms(10);
putc(buffer_in);
void inicializa(){
contador=0;
//Configuramos la UART
//TXSTA
tx9=0; // Deshabilitamos el 9 bit
txen=1; // Habilitamos la transmision
sync=0; // Seleccionamos modo ASINCRONO
brgh=1; // Establecemos el baudrate para high speed
//RCSTA
spen=1; // Habilitamos las lineas del puerto serie
rx9=0; // Selccionamos recpeción de 8 bits
cren=1; // Habilitamos recepción contínua
//SPBRG
spbrg=129; // Miramos en tablas, para high speed a 9600 corresponde el valor 129, para 19200 es 64
//Compact Flash
tris_cf_control =0x22; // port a xxoi iioi para la compact, pero para el pic es al reves xxio ooio
tris_cf_data =0x00; // port b oooo oooo
tris_cf_addr =0x80; // port c ioxo oooo
cf_control =0x18; // (RDY /WE /OE RST /CD1 /CE1) 0 1 1 0 0 0 Las entradas las dejamos a 1, /WE y /CDE
cf_addr =0x00; // 0 1 1 0 0 0
void checkready(void){
do{;
}while(!RDY);
void cfread(){
checkready(); // Esperamos a que RDY de la tarjeta este en alto
tris_cf_data=0xFF; // COnfiguramos el cf_data como todo entradas
CF_DATA=0; // Inicializamos, por si acaso
OE=false; // Lectura de la parte baja del dato
data_lo=CF_DATA;
OE=true;
checkready(); // Despues de la primera lectura esperamos para hacer la segunda
OE=false; // Lectura de la parte alta del dato
data_hi=CF_DATA;
OE=true;
tris_cf_data=0x00; // Configuramos el cf_data como todo salidas
void cfwrite(void){
checkready(); // Nos aseguramos que la tarjeta esta preparada
delay_us(5);
WE=0;
delay_ms(1);
WE=1;
void getLBA(void){
int8 lba0,lba1,lba2,lba3;
lba3=getc();
lba2=getc();
lba1=getc();
lba0=getc();
LBA=((int32)lba0)+((int32) lba1<<8)+((int32) lba2<<16)+((int32)lba3<<24);
putc(make8(LBA,3));
delay_ms(10);
putc(make8(LBA,2));
delay_ms(10);
putc(make8(LBA,1));
delay_ms(10);
putc(make8(LBA,0));
delay_ms(10);
getc();
// Para manejar un registro de la compact flash se coloca el dato en el cf_data, luego se
// coloca la dirección del registro a escribir o leer en el cf_addr y luego se baja a 0
// la correspondiente linea OE o WE para leer o escribir dicho registro.
void getdatafromcf(int32 lba){
lba = lba & 0x0FFFFFFF; // El primer byte siempre debe ser 1110 = E
lba = lba | 0xE0000000;
cf_data=make8(lba,3); // HEAD_REG = lba[3] Siempre ponemos 0xE0
cf_addr=HEAD_REG;
cfwrite();
cf_data=make8(lba,2); // CYL_HI_REG = lba[2]
cf_addr=CYL_HI_REG;
cfwrite();
cf_data=make8(lba,1); // CYL_LO_REG = lba[1]
cf_addr=CYL_LO_REG;
cfwrite();
cf_data=make8(lba,0); // SEC_NUM_REG = lba[0]
cf_addr=SEC_NUM_REG;
cfwrite();
cf_data=0x01; // SEC_CNT_REG = 0x01
cf_addr=SEC_CNT_REG; // seleccionamos que lea solo un sector
cfwrite();
cf_data=READ_SEC; // COMMAND_REG = READ_SEC
cf_addr=COMMAND_REG; // Comando para leer tantos sectores como indica SEC_CNT_REG
cfwrite();
cf_addr=DATA_REG; // Dejamos la dirección del registro de datos lista para usar
void putdatatocf(int32 lba){
cf_addr=HEAD_REG;
cfwrite();
cf_addr=CYL_HI_REG;
cfwrite();
cf_addr=CYL_LO_REG;
cfwrite();
cfwrite();
cfwrite();
cf_data=WRITE_SEC; // COMMAND_REG = WRITE_SEC
cfwrite();
void readsector(){
int16 c;
for (c=0;c<256;c++){ //Un sector son 512 bytes
cfread();
void writesector(){
int16 c;
for (c=0;c<512;c++){ // Un sector son 512 bytes
cf_data=0xAF;
cf_addr=DATA_REG;
cfwrite();
void erasesector(){
cf_data=ERASE_SEC; // COMMAND_REG = READ_SEC
cfwrite();
lucky
Joined: 12 Sep 2003 Posts: 46 Location: South Coast - England
CF Code |
Posted: Fri Jun 11, 2004 3:22 am |
Hi CHRIS,
I dont know the answe to your problem as I am only reading from my CF but my old CF code in my downloads area was able to write & read back using the CF(). Note that this is very old code & is not FAT16 aware. You should be able to compare them & spot the error tho. My new FAT 16 code will be on there soon but this only reads. _________________ Lucky
www.mpic3.com - MPIC3 player project, Forum, Downloads, Online Shop |
