I saw a recent post about version 3.2xx having some wierd behavior with int1 and was wondering if it was also true for version 3.184. If I use this code:
int1 x;
main()
x = TRUE;
The debugger shows x as 0 all the time. I've tried x = 1, x == 1, x == TRUE. All 0. But if I define x as an int it will change value correctly/as expected.
Posted: Wed Jun 09, 2004 4:14 pm
Look at the .LST file to find out what's really happening.
Here is part of the listing for your program, compiled
with PCM vs. 3.184 for a 16F877. Conclusion: No problem.
The variable x is being set = 1, as expected.
Symbol Table
x 00000020
0000 00284 .................... x = TRUE;
000A 1283 00285 BCF 03.5 // Bank 0
000B 1420 00286 BSF 20.0 // Set bit 0 of Loc 0x20 = 1
ninjanick
Posted: Thu Jun 10, 2004 1:45 pm
I checked the LST file and it is getting set, but my Debugger still reads 0. Maybe it's a bug in the debugger?
