Steve Guest
Formatted output |
Posted: Tue Jun 08, 2004 2:06 pm |
Dear All,
I have bought and regulary use the PCM compiler, which I find easy and
powerful.
As part of an assignment, I have been asked to develop a program with another compiler which does not have the comforts of the PCM compiler
Problem ->
I wish to display a clock in the correct format, i.e when the seconds tick over 9, the seconds occupy two digits i.e
under 10 = 09
above 10 = 10 (ON A LCD)
Normally I would use prinf with a format specifier, this compiler cannot give a formatted output it uses
lcd_print_ch('x');
How can I ensure the correct format is displayed, any ideas?? |
jds-pic
Re: Formatted output |
Posted: Tue Jun 08, 2004 2:25 pm |
Steve wrote: |
Problem ->
under 10 = 09
lcd_print_ch('x');
am i missing something here?
using your example...
if (x<10)
lcd_print_ch('0');
lcd_print_ch('x');
Posted: Tue Jun 08, 2004 2:26 pm |
Do a test, using the "if" statement. If the value is below 10,
then send a leading '0' character to the LCD.
Edited to add:
You beat me by 1 minute. I was trying to make him work a little. |
Posted: Wed Jun 09, 2004 2:06 am |
Steve wrote: | Dear All,
powerful.
Problem ->
under 10 = 09
lcd_print_ch('x');
As has allready been posted, you can do an 'if' test, but the other solution is to use division, and the modulus function.
So (if you 'time' is in 'val', then:
putc((val/10)+'0');
putc((val%10)+'0');
Best Wisihes |
