What is the lowest voltage I can compare reliably with PIC12F675 analog comparator with internal and external Vref?
The information in datasheet (Table 12.6 and 12-7) seem to be too new to me and find it hard to understand.
TIA,
-- dj
Posted: Sun Jun 06, 2004 3:03 pm
In theory, you should be able to measure the voltage for 1 step
above ground. With a 5v reference ( using the internal reference,
when the PIC is running at 5v), one step will be approximately 5 mv.
