dais
simple Input/output question |
Posted: Fri Jun 04, 2004 1:10 pm |
I have a question about input and output mode.
SET_TRIS_B( 0x0F ); // B7,B6,B5,B4 are outputs
// B3,B2,B1,B0 are inputs
When I do INPUT_B()
Does it change b7,b6,b5,b4 into input mode then read or it only read B0-B3, and ignore B4-B8.
Simin |
Posted: Fri Jun 04, 2004 1:27 pm |
When I do INPUT_B()
or it only read B0-B3, and ignore B4-B8. |
If you are using Standard i/o Mode, then yes, the compiler will set
the TRIS for all of Port B to be inputs, before it reads the port.
It will leave all the pins in that state.
If you are using Fast i/o mode for Port B, then the TRIS
state will not be changed by the compiler. |
Posted: Fri Jun 04, 2004 2:26 pm |
PCM, Thanks for quick reply, I will use standard IO.
Simin |
