lala Guest
What is averaging algorithm? |
Posted: Thu Jun 03, 2004 3:08 am |
hello;
What is averaging algorithm? i just study on resistive touchscreen technology and want to know how the averaging algorithm apply to this technology?
thank you |
SteveS
Posted: Thu Jun 03, 2004 8:33 am |
Since filtering comes up a lot I wrote up a real short and simple introduction to filters in the code section. Hope that helps.
- SteveS |
bdring Guest
Posted: Fri Jun 11, 2004 2:01 pm |
I often use a rolling average. You can call this hundreds or times without the need to store a bunch of values in RAM. Adjust the variable type to fit your application. It is not very fast, but it works for me.
Code: | int16 avg(int16 oldVal, int16 newVal, int8 sampleNo)
return = oldVal + (newVal-oldVal)/sampleNo;
Initialize the value to zero and call it as shown below.
Code: | oldVal = 0;
oldVal = avg(oldVal, 100, 1);
oldVal = avg(oldVal, 120, 2);
oldVal = avg(oldVal, 140, 3); |
oldVal will hold the average at every stage and end up with 130 in this case. |
