FCS Frame Check Sequence help !
horizontech
PostPosted: Tue Jun 01, 2004 5:31 pm     Reply with quote
Hi !
I need to send 12 bytes true rs232 with 2 extra byte as FCS frame check
i looking for example to understand how to compute the 2 FCS bytes ?
I have read the string on other transmiter :
255 255 000 008 000 034 000 000 000 002 001 255 176 038
255 255 000 008 000 034 000 000 000 002 002 255 173 040
the last 2 bytes on each example is FCS !
Thank you very munch for all your help !
Alain Tanguay
Haplo
PostPosted: Tue Jun 01, 2004 5:45 pm     Reply with quote
It seems you are using HDLC, correct? This is how I calculated fcs in a project long time ago...
unsigned int check (char *frame, int nbytes)
   unsigned char ch;
   unsigned bit, fcs;
   int i, j;
     * Initialize the fcs.
   fcs = 0xFFFF;
     * Look at each character in the frame.
   for (i = 0; i < nbytes; ++i)
      ch = frame [i];
      fcs ^= ch;
        * Look at the LSB of the fcs 8 times.
      for (j = 0; j < 8; ++j)
         bit = fcs % 2;
         fcs >>= 1;
           * Now, do an exclusive-OR between this bit and bits 3, 10, and 15 of the
           * fcs, without disturbing the other bits.
         if (bit) fcs ^= 0x8408;
     * Lastly, take the ones complement of the fcs.
    fcs = ~fcs;
    return (fcs);
horizontech
PostPosted: Wed Jun 02, 2004 6:15 pm     Reply with quote
Thanks for info
I looking for a step by step calculation for understand how is work ?
Thanks for your time
Alain tanguay
Haplo
PostPosted: Wed Jun 02, 2004 8:11 pm     Reply with quote
I think the comments in the code are pretty intuitive, I can't give you any more information than it's already there Very Happy
Bear in mind that what I posted is the FCS algorithm for HDLC. Yours might be different. Does it return the same result as you are expecting?
